| Author |
Message |
dande man Regular
Posted: Sat Dec 08, 2012 7:10 pm Post subject: HCooke--stumped |
did you get it running if so what was the problem?? |
| Back to top |
HCooke Tractor Expert
Posted: Sun Dec 09, 2012 5:31 am Post subject: Re: HCooke--stumped |
Not running yet. So far I have swapped the dist from a running tractor; I have swapped the carb from a running tractor; I have swapped manifolds. I replaced the manifold gaskets. I removed the valve cover gasket and observed the valves moving up and down - looked normal to me. I have hotwired the coil (bypassing the switch and the resistor). I have removed the exhaust pipe. I will run for about 3 sec if you spritz carb cleaner into the throat of the manifold and apply the choke. |
| Back to top |
Roger in Iowa Long Time User
Posted: Sun Dec 09, 2012 6:35 am Post subject: Re: HCooke--stumped |
Try another manifold. |
| Back to top |
Roland (AL) Regular
Posted: Sun Dec 09, 2012 1:10 pm Post subject: Re: HCooke--stumped |
Hook up a temp fuel tank that might solve the problem.
Later Roland (AL) |
| Back to top |
Ken(Ark) Long Time User
Posted: Sun Dec 09, 2012 1:28 pm Post subject: Re: HCooke--stumped |
Does it have good suction ? With the elbow pipe off and the palm of your hand over the end of the carburetor , can you feel a strong suction ?
Usually I can keep a motor running with a spray bottle of gas or a can of starting fluid if it is a fuel problem .
If not it is usually spark or timing . The suction would be a good indicator on the timing of the valve opening/closing at the right time .
How about the valve clearance ? Probably not the problem but if they are too tight the compression will not build up enough to explode .
Last thought , burn off the spark plugs . Some times fouled plugs look good but if three are not sparking then it will only run a few seconds . |
| Back to top |
souNdguy Tractor Guru
Posted: Mon Dec 10, 2012 7:26 am Post subject: Re: HCooke--stumped |
comp test? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
