| Author |
Message |
Connor New User
Posted: Sat Dec 08, 2012 8:43 pm Post subject: IH 2 Row Corn Planter Row Markers |
I just bought a really old IH Corn planter, with the big 18"+ wheels in the back and a seat to sit on it.
Its in really good shape for its age, little rust, etc.
My problem is that the row markers are missing.
Does anyone know how I can make some or what they should look like?
And how do I set them up when planting?
Thanks |
| Back to top |
sideconsole4020guy Regular
Posted: Sun Dec 09, 2012 6:35 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
I might have what the markers you are looking for. Can you post a picture of the planter you have?
Zach |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6411 Location: Delta,colorado
Posted: Sun Dec 09, 2012 7:11 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
you dont need markers on a 2 row.just line up the tirew with the last tire track.Or hang a 2x4 across thefront of the tractor and let a chain dangle over the last row planted. the thing to do is to not concentrate on the last row(that will only cause crooked rows),'Eyeball" the other end of the field ane drive toward that.Dont worry if the 'guessrow is a little 'off'.With a little practice you will be straight as a 'fiddle string'. |
| Back to top |
Posted: Sun Dec 09, 2012 7:14 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
One more thing.A planter as old as your's could be a 'checkrow' planter.If so,its a yard ornament.Find out for sure.post a pic,please. |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9413 Location: Wapakoneta, Ohio
Posted: Sun Dec 09, 2012 7:48 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
If you have a seat then you have a horse drawn planter but I have never seen one with that small of wheels on it and 18" is a small wheel, normal wheel is about 33" in diameter and having a seat unless it is a lister or bedder planter and those could have an 18" wheel as they were never in the area around Ohio the chances are 99.9% that it is a check row planter. May be some around if a normal shoe planter. Your description does not match any standard type of McCormick corn planter and I work with people that still use them behind the horses. |
| Back to top |
Leroy Tractor Guru
Posted: Sun Dec 09, 2012 7:53 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
Once you can try to get a picture posted and give us a location so we can figure out the type of croping system that was used there, flat land, planting in borrom of furrow in arid locations for water conservation or planting on top of ridges for either flood irigation or to ceep the plants up out of standing water. That all can help identify the type of planter and once identified then can come up with possible parts for it. |
| Back to top |
Connor New User
Posted: Sun Dec 09, 2012 9:32 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
I'm not sure if it will work, but here is a link to the craigslist ad that it was on.
Everything works I dont see why if it is a checkrow planter that I couldn't use it...
Untitled URL Link
| Back to top |
Posted: Sun Dec 09, 2012 11:22 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
The link doesnt work...With a 'checkrow',you will need a speacial knotted wire(the length of your field) to trip it to make it drop seeds in to hills(42" apart).I supposed if someone rode the planter they could trip it manually... |
| Back to top |
DoubleR Long Time User
Posted: Sun Dec 09, 2012 11:49 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
I plant with a old steel wheel IH two row planter with markers. I just use the tractor wheels for markers most of the time though. I think its easier for me anyway. |
| Back to top |
Connor New User
Posted: Sun Dec 09, 2012 11:51 am Post subject: Re: IH 2 Row Corn Planter Row Markers |
here is a pic, i dont think its a checkrow but you guys tell me..
| Back to top |
Posted: Sun Dec 09, 2012 12:57 pm Post subject: Re: IH 2 Row Corn Planter Row Markers |
I have a parts planter like that and a double hitch to hook 2 of those planters together to make a 4 row tractor planter. Its a factory McCormick hitch. Its for sale too. |
| Back to top |
Connor New User
Posted: Sun Dec 09, 2012 1:00 pm Post subject: Re: IH 2 Row Corn Planter Row Markers |
do you have the row markers for sale?
how much do you want for it??
and you can email me, use this email so not everyone
online can see my email:
vcsnc-3398494615@sale.craigslist.org
Thanks |
| Back to top |
Posted: Sun Dec 09, 2012 1:26 pm Post subject: Re: IH 2 Row Corn Planter Row Markers |
It has the row markers although they would be too long but it would be easy to shorten them. The markers are for sale as is the whole thing. I can get pictures in a day or 2 when it stops snowing as it it at a different farm site |
| Back to top |
Leroy Tractor Guru
Posted: Sun Dec 09, 2012 3:40 pm Post subject: Re: IH 2 Row Corn Planter Row Markers |
That is a drill version of the check planter as it never had the check heads on it. Am not sure of model number. It was a hand lift unit that was converted to a 3 point and then without taking the 3 point off they put a tractor toung hitch on it and it is now set up to operate from the drawbar of a tractor with the seat set clear to the back, not like the tractor the 3 point was put on for. I know a parts planter byt do not know if it has markers. |
| Back to top |
Leroy Tractor Guru
Posted: Sun Dec 09, 2012 3:43 pm Post subject: Re: IH 2 Row Corn Planter Row Markers |
The markers for use with the 2 planter hitch would be on the hitch and not the planter and they would be the length for 4 rows and not 2. |
| Back to top |
