| Author |
Message |
FWB in SK Regular
Posted: Sun Dec 09, 2012 10:33 am Post subject: Late 8N rear hub |
Late 8N with worn rear hubs. Has any one had any luck with trying to put shims on axel to try to tighten up hub. Or remove metal from back of hub so when you tighten the axle nut hub won't rub on bearing cage. |
| Back to top |
JMOR Tractor Guru
Posted: Sun Dec 09, 2012 10:47 am Post subject: Re: Late 8N rear hub |
| FWB in SK wrote: | | (quoted from post at 14:33:17 12/09/12) Late 8N with worn rear hubs. Has any one had any luck with trying to put shims on axel to try to tighten up hub. Or remove metal from back of hub so when you tighten the axle nut hub won't rub on bearing cage. | Dave or Zane or both maybe, I think, has talked of using strips cut from hard banding strap material. I just get a new hub & axle when needed. It is most likely the back of the lug studs hitting, since they are rear most parts, so I'm not sure what material you would remove? If hub &/or axle are worn that much, then you run into situation where nut/washer tightens against axle shoulder & hub remains loose on splines. New hub & perhaps new axle to fix. |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Sun Dec 09, 2012 4:31 pm Post subject: Re: Late 8N rear hub |
I tried it one time on one of my N's (Zane's banding strip trick).. Its been used 60 hr's and no issues... Hubs on a 8N are a P>O>S> to start off with... I have no problem with this on my own but would never do it on a customers tractor... |
| Back to top |
Royse Tractor Expert
Posted: Sun Dec 09, 2012 4:53 pm Post subject: Re: Late 8N rear hub |
You don't necessarily need new-new either.
I got a pair of good used ones from John Smith that have worked great.
Jim.UT may have a set on hand too.
They're not terribly expensive.
Links below
John Smith's site
Jim's parts list |
| Back to top |
russb wa Regular
Posted: Sun Dec 09, 2012 4:56 pm Post subject: Re: Late 8N rear hub |
I have always wondered why there isn't someone somewhere who has come up with a fix, well, fix might not be the right word, but an "improve".
Maybe like having the axle plated, or something like the shims mentioned. They knurl and peen to raise some metal. Along that line one might think peen with a punch, but the metal might be too hard, many variables. You'd have to be lucky or pure of thought.
How about drill and tap across the hub into the splined section. Then after assembly using a bolt as a plunger to force epoxy or JB weld into the joint. Like the song says, "nothin from nothin leaves nothin". |
| Back to top |
russb wa Regular
Posted: Sun Dec 09, 2012 5:03 pm Post subject: Re: Late 8N rear hub |
Yeah, I think it would be tough to get apart if you epoxied it together. Better be careful when listening to me. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
