Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Camshaft information
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
1939A
PostPosted: Sun Dec 09, 2012 3:48 pm    Post subject: Camshaft information Reply to specific post Reply with quote
I am working on degreeing in my camshaft on my A . It calls for 108 degrees and that is were i have it. My question it should the intake valve close at bottom dead center in the dwell time or after it goes through the lost motion of the crank. I hope this makes sense im just wanting to double check all my baises before i put it back together tha ks for any help. The cam card says 108 degree and 112 overlap
Buzzman72
PostPosted: Sun Dec 09, 2012 5:06 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
Try this link:
Degreeing A Camshaft
Gary Baker
PostPosted: Sun Dec 09, 2012 7:22 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
112 lobe seperation is not good. Who ground your cam?
1939A
PostPosted: Sun Dec 09, 2012 9:51 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
I would rather not say who built the cam , they done all my work and have been happy just thought the intake valve should b closed be for the piston starts up on compression. I could advance it and give up some on the exaust side but i think that would be better.
buickanddeere
PostPosted: Mon Dec 10, 2012 6:27 am    Post subject: Re: Camshaft information Reply to specific post Reply with quote
That is why they call it a long duration cam with overlap.
There is supposed to be enough airflow and velocity that the cylinder is still filling during the very early stages of the compression stroke.
How many rpm are you hoping for ?
1939A
PostPosted: Mon Dec 10, 2012 3:22 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
We are running 10% overstock. Could i retard the if i retard the cam a couple degrees i think the exaust wont be fully closed when it starts the intake side . It runs pretty good just trying to get a little more out of it. Thanks for all the help
north puller
PostPosted: Mon Dec 10, 2012 6:28 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
Would 112 LSA be stock for an A? I know when I was calling around about 2 cylinder cam grinds, many of the grinders would only add lift and duration, but not change valve timming.
north puller
PostPosted: Mon Dec 10, 2012 6:41 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
My 70 cam is timmed at 108. I run 10% over stock also. I would see if you could advance the cam a bit more - say 105 or 106.
My grind has 105 LSA. Engine works good, but could use a little more lug. I don't think that 112 LSA is going to give you what you want.
May want to consider something different. Josh Blackburn or Gary Baker can give you a better cam grind. Rumor is that they worked together developing a cam grind for A/60's.
rumor has it
PostPosted: Mon Dec 10, 2012 6:48 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
Speaking of rumors, didn't this motor come from josh?
1939A
PostPosted: Mon Dec 10, 2012 7:37 pm    Post subject: Re: Camshaft information Reply to specific post Reply with quote
No this motor did not come from josh i wasnt aware of him when i built this motor from the things i have seen and learned he appears to knowwhat he is talking about. When i get my A together im going to work on my little boys G and i will talk with him. Thanks to all that have giving me advice im still learning
buickanddeere
PostPosted: Tue Dec 11, 2012 9:22 am    Post subject: Re: Camshaft information Reply to specific post Reply with quote
Retarding the cam reduces low rpm lug and increases peak rpm power.
You want to run the cam moderatly advanced to increase low end torque.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
