Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
acceptable PTO share overlap
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
Steve in VA
PostPosted: Mon Dec 10, 2012 11:21 am    Post subject: acceptable PTO share overlap Reply to specific post Reply with quote
I have a new-to-me PTO driven 6' tiller. The previous owner cut the drive shaft to fit his compact tractor. Too much tiller for his tractor so now it's mine. I dislike buying one or both ends unless I really need to. By my measurements, I'll have ~5" of overlap between the two sliding halves. So, in your experience, am I being foolish in not replacing 1 or both halves to get the max overlap? Thanks in advance.
Mike (WA)
PostPosted: Mon Dec 10, 2012 12:16 pm    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
5 inches should be enough- I assume that's the overlap when you're actually in tilling position and working. Most tillers have adjustments for the attachment point of the 3 point pins to make the shaft as straight as possible when working.
Just be careful when lifting, that you don't lift it far enough for the shaft to come apart. Might want to practice a little before engaging PTO, and putting a stop on the lift lever so tiller only lifts far enough to clear the ground.
RickB
PostPosted: Mon Dec 10, 2012 1:56 pm    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
Most equipment op manuals specify 6" of overlap. I'll bet 5 will be OK.
DeltaRed
PostPosted: Mon Dec 10, 2012 3:23 pm    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
Mike&Rick each have the right idea.
Eric in IL
PostPosted: Mon Dec 10, 2012 3:50 pm    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
If you are really worried about the correct overlap, I would bet that a P.T.O. extension for the tractor is much cheaper than a new shaft.
IaGary
PostPosted: Mon Dec 10, 2012 7:19 pm    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
Some PTO shafts have a 4" square piece welded to the end of a round shaft.
So if 4" is enough 5 should be as well.
Gary
Nathan (SD)
PostPosted: Tue Dec 11, 2012 12:01 am    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
24 inches or less overall shaft length and 5 inches should be fine.
Steve in VA
PostPosted: Tue Dec 11, 2012 3:08 am    Post subject: Re: acceptable PTO share overlap Reply to specific post Reply with quote
thanks for the feedback and also for the concensus. Eric - the idea of the extension is really out-of-the-box thinking and sure works for me as the fall-back. The dimensions I gave were in the fully dropped/tilling position.
Thanks again guys.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
