| Author |
Message |
FarmallPaul Regular
Posted: Tue Dec 11, 2012 11:17 am Post subject: M5 Wide Front Problem |
Hi! I have an early M5 (50th one built), and I"ve only had for about a year now. The front end is an adjustable wide front, but it"s square like older ZAE stuff. Well, the problem is that this weekend I got down in a small rut, with the wheels cranked to the side, and a BIG bale on the loader spike, and I broke the center steering arm. It had already been welded, in fact it looks like it is custom made for using the older front end on this M5. I will need to get a replacement, but don"t know if a standard adjustable wide front center arm for an M5 will work, or if I need to get something else? Has anybody ever done/seen this combination? Or does anybody know any good cast welders...... Thanks-
| Back to top |
mmdiesel Regular
Posted: Tue Dec 11, 2012 12:21 pm Post subject: Re: M5 Wide Front Problem |
The M5 wide front end should be more rounded. Your front end is the same as my older UB diesel. Maybe you can see a difference in my picture. I would be happy to answer more questions.
Michael Moeller
mmdieselpuller@yahoo.com
| Back to top |
molinegb Long Time User
Posted: Tue Dec 11, 2012 12:33 pm Post subject: Re: M5 Wide Front Problem |
Axle pictured is extendable axle used on RTE,ZTE,ZAE and UTE as well as UBE. I would say way too light for any loader! |
| Back to top |
FarmallPaul Regular
Posted: Tue Dec 11, 2012 12:41 pm Post subject: Re: M5 Wide Front Problem |
Thanks- That's what I thought, but didn't realize it was too light. Do you know if the center arm from any of those models would work with this front end on this tractor? |
| Back to top |
FarmallPaul Regular
Posted: Tue Dec 11, 2012 12:43 pm Post subject: Re: M5 Wide Front Problem |
Thanks, that's what I thought. Have you got a center arm you'd be willing to sell? How about a whole round tube front end? |
| Back to top |
Posted: Tue Dec 11, 2012 12:51 pm Post subject: Re: M5 Wide Front Problem |
Any tube "E" axle of a M5,M602,5 Star, M670 will fit. A standard axle would be stronger but more changes would be required. |
| Back to top |
FarmallPaul Regular
Posted: Tue Dec 11, 2012 1:33 pm Post subject: Re: M5 Wide Front Problem |
I'm mostly going to be using this for a loader and mowing, so I don't need adjustable. What all would need to be done to put a standard (non-adjustable) wide front axle on there? |
| Back to top |
Posted: Tue Dec 11, 2012 1:53 pm Post subject: Re: M5 Wide Front Problem |
Bottom of pedestal has to be changed as pin and clevis assembly heavier. Also mounting to belly housing must be put on. Probably getting tough to find. In western Canada basically all we have are the standard axles. They also use wider rims.I have never seen one break! |
| Back to top |
Jeff Gravert Regular
Posted: Tue Dec 11, 2012 3:42 pm Post subject: Re: M5 Wide Front Problem |
I would have either a complete round tube style front axle or a standard non adjustable style that would be correct for your tractor. Jeff Gravert Central City, NE 308-940-0255 |
| Back to top |
navyreteocs Regular
Posted: Fri Dec 14, 2012 5:34 am Post subject: Re: M5 Wide Front Problem |
I had a wide front M5 with a loader . would not steer or stop some was breaking at all time spent a lot of dollars still had a M5 .
Found me a 4010 lp have had no problems feed hay or streening stopping ect . i know the where abouts of a round m5 front end in Kansas. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
