Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Angle distributor
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
JoseinNM
PostPosted: Tue Dec 11, 2012 11:48 am    Post subject: Angle distributor Reply to specific post Reply with quote
My timing light shows 20 advanced degrees at all speeds idle to wide open. It starts great, runs strong, pulls any load I hook up, doesn't over heat, doesn't try to run on when I turn off, but as all can see, we have not any changing advance. Should I send $$$ to YT for parts or maybe distributor or just run her and be happy with $$$ that I save? What do you experts think? I mean experts, not just those who print big numbers of opinions. Everyone has opinion, but not all are experts. Thank you experts for helping us not experts.
Agman WallisTX
PostPosted: Tue Dec 11, 2012 12:03 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
If it is not broke do not fix it. If it is working doing what you want it to just keep running it.
souNdguy
PostPosted: Tue Dec 11, 2012 12:21 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
have you inspected the advance mechanism?
R Geiger
PostPosted: Tue Dec 11, 2012 12:22 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
JoseinNM wrote:
(quoted from post at 04:48:05 12/12/12) My timing light shows 20 advanced degrees at all speeds idle to wide open. It starts great, runs strong, pulls any load I hook up, doesn't over heat, doesn't try to run on when I turn off, but as all can see, we have not any changing advance. Should I send $$$ to YT for parts or maybe distributor or just run her and be happy with $$$ that I save? What do you experts think? I mean experts, not just those who print big numbers of opinions. Everyone has opinion, but not all are experts. Thank you experts for helping us not experts.
I am far from an expert, but something is wrong. I don't think that it would start that far advanced. Why did you check it? have you tried changing the timing? If it runs good I would leave it as is and sell the timing light.
souNdguy
PostPosted: Tue Dec 11, 2012 12:29 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
that's what I'm wondering, if the advance is freely moving and working, anbd perhaps theres an issue with the lamp, or reading the lamp.. if it really is starting good, running fine at all rpm ranges and taking up load..e tc..
Dean
PostPosted: Tue Dec 11, 2012 12:38 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Most likely the advance mechanism is stuck or damaged. Not uncommon.
What is "idle" RPM?
Dean
Bill Rowles
PostPosted: Tue Dec 11, 2012 12:51 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
I thought my NAA was running fine last year, but decided to put new points in it because they were a little burned. While working on the distributor I checked the mechanical advance under the points and found the parts rusty and stuck....it was not advancing. After cleaning and lubricating and installation of new points, I was surprised to find how much smoother the engine runs and the power under heavy loads seems better too. Just a thought for your consideration
Dell (WA)
PostPosted: Tue Dec 11, 2012 1:15 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Jose........fer the 5-nipple sidemount 8N dizzy, it should be 4* at idle (400rpms) and auto-advance 16* for a total of 20* by 1200rpms. Sounds like yer UNDER the PLATE centrifugal advance is STUCK WIDE-OPEN. Time to remove the plate (held in by ring) and "operate" .......Dell
JoseinNM
PostPosted: Tue Dec 11, 2012 1:47 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Look responses. That why I asked for experts. I only wanted to know if should do anything since operationally all is good. Maybe my bad. Maybe should said, will constant 20 hurt anything? No need to tell me stuck or inspect or won't start (I said it does) as those are clear to anyone. Happy idle too. Just simple yes or no from expert (one who really knows), can any damage be done at always 20 all the time?
Am I clear enough this time?
Manny thanks!
Bruce (VA)
PostPosted: Tue Dec 11, 2012 2:16 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
" Am I clear enough this time?"
Yes, I think you are very clear.
Clear enough that you will probably not get another response from anyone here.
Bob Harvey
PostPosted: Tue Dec 11, 2012 2:20 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Yes & No.
old
PostPosted: Tue Dec 11, 2012 2:59 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Will it hurt well just figure it this way would you want to run your car that way?? As in over the long run it may in fact cause burned valves by the timing being off but that could take many many hour of operation. Your call as it could be as simple as some one using a points hold down bolt that is way to long and that can mess up timing. But as others have said the way your coming at this only serves to make it so people will not want to help you help your self. You get more flys with honey then you do with vinegar
carlntexas
PostPosted: Tue Dec 11, 2012 4:45 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Jose don't think your going about this the right way kind of rude and crude.
JoseinNM
PostPosted: Tue Dec 11, 2012 4:52 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
OK, sweetie, I will take that as a maybe.
I was told I could get good answers here.
U r the only one that tried.
Manny thanks,
Love & kisses to all
old
PostPosted: Tue Dec 11, 2012 5:43 pm    Post subject: Re: Angle distributor Reply to specific post Reply with quote
Many many people here will help you and Dell did tell you how to check things out. I did tell you what may happen but then it may not happen. Either way it would be a good idea to do as Dell said and make sure what is wrong and also if you do not have it get an I-T FO-4 manual so you have info in hand
Goto page 1, 2  Next
Page 1 of 2
