Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1891 Argintine Rifle pictures both sides
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
old
PostPosted: Tue Dec 11, 2012 2:46 pm    Post subject: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Ok so here it what the rifle looks like from both sides. Maybe you guy will know better what it is this way
CHUCK CAMBIS
PostPosted: Tue Dec 11, 2012 6:38 pm    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Military rifle redone with sporter stock. Argentine rifles are listed by size but going by the vintage my first guess would be a 7x57 (7mm mauser). that cartridge became very big around then and could be bought in many countries. Markings, signs, letters or numbers may indirectly identify it. whats it got?
old
PostPosted: Tue Dec 11, 2012 8:41 pm    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Serial number is N7459. Other then that I know very little about it but then if you have read my other posts on this you would maybe understand a lot more
Bret4207
PostPosted: Wed Dec 12, 2012 4:24 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Yup, sporterized 91 Argie. I'd take a real close look at that bolt handle root/receiver area I was talking about. If the root isn't right down touching the receiver you'll have problems with the stud if it's there and even if it isn't, it can still give you issues.
If you've got it so it will work, it could just be a confluence of things coming together to create the need for a lightly longer FP. You seem to have solved the issue, so I'd proceed carefully and be alert for any indication of problems. Back when I had the gunshop I've had to remake more than one FP just a little longer to get reliable ignition.
Another thing I'd look at is I'd take the bolt back apart and soak the stripped bolt body in my favorite solvent. Then I'd use a screw driver or something to make sure there's no gunk down in the front that might be blocking the FP fall. As anyone who works on tractors knows, sometimes gunk can mess things up just enough to require a bit more power or fall to get things to work.
keh
PostPosted: Wed Dec 12, 2012 5:33 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Nice job sporterizing the M91. Is that a peep sight on the receiver?
KEH
old
PostPosted: Wed Dec 12, 2012 8:33 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Yes that is a peep site but that is also how I got this rifle many many years ago. Now finally after hanging on the wall for years I now have it shooting again
old
PostPosted: Wed Dec 12, 2012 8:35 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Only markings if has are the ones that where there when made as in the 1891 Argentine Mauser and the serial number and that is it.
old
PostPosted: Wed Dec 12, 2012 8:41 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
I did clean the bolt when it was apart and did my best to remove any and all gunk it had in it as per what Al in ARK had told me on the phone. I used carb cleaner spray and a couple of barrel brushes and some Shooter Choice copper removes stuff I have in my gun cleaning case which by the way is one of those fot by foot but 2 foot tool boxes where I keep my gun cleaning stuff and some other stuff that I have no clue as to what the parts are. Guess I should pull the parts and pieces out and take a picture or 2 and maybe you guy could tell me what I have
jackinok
PostPosted: Wed Dec 12, 2012 8:53 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
I like it! built two this last summer using peeps,a 93 spanish and a 98 turkish. working as time allows on restocking a 03-a3 springfield now.ive scoped it,but can remove the scope and use the original peep if needed.replaced the original front with a banded base and wider aftermarket sight. makes it much easier to see with my poor old eyes.
old
PostPosted: Wed Dec 12, 2012 9:35 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
I plan on selling it. I want to scale down some so I have fewer sizes of ammo to deal with and it being an odd ball it just does not fit in with the plans. I already have 4 other size rounds I keep on hand and this one would make it 5 so makes since to sell this one and buy another one that uses the same ammo as I already use most of the time
Bret4207
PostPosted: Wed Dec 12, 2012 1:01 pm    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
jackinok wrote:
(quoted from post at 09:53:08 12/12/12) I like it! built two this last summer using peeps,a 93 spanish and a 98 turkish. working as time allows on restocking a 03-a3 springfield now.ive scoped it,but can remove the scope and use the original peep if needed.replaced the original front with a banded base and wider aftermarket sight. makes it much easier to see with my poor old eyes.
Jack, one of my favorite rifles is a ratty old 95 Mauser 7x57. Wears an equally ratty old Bishop stock and a Williams peep. I think I've actually carried that rifle and shot more stuff with it than anything other than my 22's and trusty old 16 ga Ithaca. Just one of those guns that seems to hits whatever its pointed at. I don't think I could get $100.00 for it, but I wouldn't take $500.00! There's no flies on the grand old 7x57!
old
PostPosted: Wed Dec 12, 2012 2:27 pm    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
So now if you had to take a guess as to how much this 1891 Argentine is worth what would you say???
Bret4207
PostPosted: Thu Dec 13, 2012 4:33 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
IMO most any centerfire rifle in good repair is worth at least $100.00. That rifle I would say a max would be in the $250.00 area. It's sporterized, not original. That decreases value in a rifle like the 91. I'm sorry but the demand for rifles like that just doesn't exist anymore. In original military clothes it might be worth up over $500.00.
old
PostPosted: Thu Dec 13, 2012 10:12 am    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Yes I understand that the demand for such a rifle is not way up there and due to what has been done makes it less so. My self I like the old Russian rifles and hand guns due to the fact they seem to be some of the hardest built weapons I have seen and ammo is for the most part easy and cheap
RGMartin
PostPosted: Thu Dec 13, 2012 2:22 pm    Post subject: Re: 1891 Argintine Rifle pictures both sides Reply to specific post Reply with quote
Bret4207 wrote:
(quoted from post at 08:33:26 12/13/12) IMO most any centerfire rifle in good repair is worth at least $100.00. That rifle I would say a max would be in the $250.00 area. It's sporterized, not original. That decreases value in a rifle like the 91. I'm sorry but the demand for rifles like that just doesn't exist anymore. In original military clothes it might be worth up over $500.00.
I think you are being generous on your estimate. I would expect to see a $150 price tag on that at a local shop, and it would languish in the rack. It has most everything going against it, obscure caliber, weak action, sporterized, funky magazine.
The only thing it really has going for is the fact it is an antique/pre 1899.
Goto page 1, 2  Next
Page 1 of 2
