Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
new crawler.
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
KluegCollector
PostPosted: Tue Dec 11, 2012 5:20 pm    Post subject: new crawler. Reply to specific post Reply with quote
Just bought a JD 440 IC. just played around on it less than a day after having it and one of the tracks cracked. Whats the best thing to do? get a small section of track or have the casting welded back up?
Lou from Wi.
PostPosted: Tue Dec 11, 2012 6:24 pm    Post subject: Re: new crawler. Reply to specific post Reply with quote
Are you talking track chain link or track pad?
LOU
DGH
PostPosted: Tue Dec 11, 2012 7:35 pm    Post subject: Re: new crawler. Reply to specific post Reply with quote
The track links are a high strength material.
Use a 11018 or 6010 5P+ Lincoln rod for welding.
For a track shoe, any mild steel rod will work.
LJD
PostPosted: Wed Dec 12, 2012 5:10 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
I don't know what exactly you broke. If it's a track chain-link - it probably broke because it's worn too thin and way past it's original hardened exterior. In that case, welding is a waste of time if you really want to use the machine for any work.
Stick welding
PostPosted: Wed Dec 12, 2012 11:12 pm    Post subject: Re: new crawler. Reply to specific post Reply with quote
Why would you use 6010? Not even close to 11018. I've welded broken links with 7018 and never had a problem.
DGH
PostPosted: Thu Dec 13, 2012 9:35 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
The 6010 5P+ is the Lincoln designation for their 11060 rod which is the same strength as the 11018 but is not a low hydrgen rod. It is readily available and quite a popular rod around here. It is easy to use and good for out of position welding with a light slag cover.
DGH
PostPosted: Thu Dec 13, 2012 9:41 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
the 11060 should read 11010!!
Stick welding
PostPosted: Thu Dec 13, 2012 10:12 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
I'm VERY familiar with 5P+. It is Lincoln's improved 6010. Came out in the late 80's as a smoother running 5P which was the industry standard for decades. There is no such thing as 11010. The highest XX10 rod is a 9010 but most XX10 rods over 6010 are used almost exclusively for downhand pipeline welding. An XX10 would not be the rod to use to weld up anything on an undercarriage.
DGH
PostPosted: Thu Dec 13, 2012 10:20 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
Well you better read the spec's for the 6010 5P= because it is a 11010 class rod!
Stick welding
PostPosted: Thu Dec 13, 2012 10:39 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
I currently work...
in a welding supply store with the Lincoln welding consumables book right in front of me. The 6010 IS the rod classification!!! 60,000 psi tensile, all position with a cellulose coating. AWS classification E6010. I've also been a licensed interprovincial red seal welder for close to 30 years. I think you should have your facts straight before you try to correct anyone. LoL
DGH
PostPosted: Thu Dec 13, 2012 11:09 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
Well get yourself a 6010 rod and a 6010 5P+ rod and try to cut each on with some cutting pliers. You will find the 5P+ rod is much harder!! A normal 6010 rod and a 6010 5P+ rod are not the same!!
Stick welding
PostPosted: Thu Dec 13, 2012 12:25 pm    Post subject: Re: new crawler. Reply to specific post Reply with quote
It's still a 6010 class rod. You don't measure the strength of a welding rod but how hard it is to cut with side cutters, otherwise you might as weld everything with hard facing rod.
Stick welding
PostPosted: Thu Dec 13, 2012 12:34 pm    Post subject: Re: new crawler. Reply to specific post Reply with quote
Sorry, that should buy not but and might as well.
mnoliverguy
PostPosted: Sat Dec 15, 2012 10:12 am    Post subject: Re: new crawler. Reply to specific post Reply with quote
Drama Queen still has a job?????????
