Compression Testers
BigBob706
PostPosted: Wed Dec 12, 2012 7:29 am    Post subject: Compression Testers Reply to specific post Reply with quote
Im looking to buy a compression tester. Im going to use it for my tractor. Not sure if I need a specific one. Any suggestions on a good one?
Allan in NE
PostPosted: Wed Dec 12, 2012 7:31 am    Post subject: Re: Compression Testers Reply to specific post Reply with quote
Doesn't matter, but make sure it has all the adaptors.
Allan
old
PostPosted: Wed Dec 12, 2012 8:46 am    Post subject: Re: Compression Testers Reply to specific post Reply with quote
Most any auto parts store sell them and most you can buy for less then $20 and they come with the adapters to fit all the common plug sizes. Only plug hole I have that mine will not fit in is my 1935 JD B which uses a very big plug
rustred
PostPosted: Wed Dec 12, 2012 9:32 am    Post subject: Re: Compression Testers Reply to specific post Reply with quote
gas ones are the same , but not good for diesels.
jim_uny
PostPosted: Wed Dec 12, 2012 2:52 pm    Post subject: Re: Compression Testers Reply to specific post Reply with quote
you should get fittings for applications you want and eval psi range desired. then go to www.sears.com
search parameter " compression tester kit "
many to choose from. OTC etc. spend > $ 80 and you will have a good tool for life.
Fullers Farmalls
PostPosted: Wed Dec 12, 2012 7:04 pm    Post subject: Re: Compression Testers Reply to specific post Reply with quote
If you have a gas tractor the one that I got was from Harbor Freight. It was cheap and it works good.
Pete in Holland, MI
PostPosted: Fri Dec 14, 2012 11:21 am    Post subject: Re: Compression Testers Reply to specific post Reply with quote
Yea, the big plugs are tough to find adaptors for.
I took an old plug, broke out the ceramic, filled it with JB weld, redrilled & tapped with one of the smaller metric sizes in my Harbor Freight kit. Works well. Cheap spark plug taps are available at Auto Zone or similar places.
Pete
