Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Case 400 Smokes but won't start
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
nayr272
PostPosted: Wed Dec 12, 2012 8:25 am    Post subject: Case 400 Smokes but won't start Reply to specific post Reply with quote
I have been working on a case 400 diesel that I
cannot get to run we pulled it for 30 minutes, it
smokes but will only run on either and we had it
plugged in overnight.
any ideas? Thanks.
j hikemper
PostPosted: Wed Dec 12, 2012 8:31 am    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
remove air filter neck ,need more history info ,. if fuel pump removed ,, the timing is not rite ,.800b caused a lot of good fellas round here to loose their religion , before we finally timed it up rite ...
830 man
PostPosted: Wed Dec 12, 2012 8:56 am    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
Compression test may be in order.
nayr272
PostPosted: Wed Dec 12, 2012 9:00 am    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
the timing should be fine the engine has never been taken apart, however it ranaway on my dad about two years ago and we just got the pump fixed.
830 man
PostPosted: Wed Dec 12, 2012 9:14 am    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
Was the pump removed to be fixed? If so tje pump timing may be off.
nayr272
PostPosted: Wed Dec 12, 2012 9:25 am    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
yes the pump was off, I realized that now after looking closer at the manual I guess I thought that It could only go on one way because there is one tooth that is bigger than the rest.
EliG
PostPosted: Wed Dec 12, 2012 12:53 pm    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
First of all I would recommend not using ether on this engine. Eventually the heads will crack.
Timing has been mentioned.
Is the compression turned on? The lever under the dash on the right hand side should be parallel to the steering column (pointed down) for it to be on.
Has the fuel system been bled properly and is the transfer pump bypass valve closed on the first stage filter housing?
Are the throttle linkages hooked up correctly and is the control arm on the pump indexed properly? If any of this is out of adjustment it may be getting enough fuel to smoke but not fire.
How is the block heater plumbed? When I got my 400 diesel the outlet of the heater was plumbed into the plug on the top of the water manifold. This did a good job of heating the radiator and left the block stone cold. During the overhaul I plumbed the new 1000 watt heater into the plug on the left side of the engine towards the front of the block. It easily heats the water to 100+ degrees in about 1 hr.
Good luck and keep us posted.
nayr272
PostPosted: Wed Dec 12, 2012 3:40 pm    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
Got it running, the pump was 180 degrees off.
RGMartin
PostPosted: Wed Dec 12, 2012 3:54 pm    Post subject: Re: Case 400 Smokes but won't start Reply to specific post Reply with quote
nayr272 wrote:
(quoted from post at 19:40:02 12/12/12) Got it running, the pump was 180 degrees off.
Don't feel too bad, I did that to a 970 once. It ran, but wasn't happy about the experience. Smoked like a coal fired train, terrible throttle response, wouldn't idle. Didn't know they would run 180 out.
