Honda Civic Rad. in 77???
showdown
PostPosted: Wed Dec 12, 2012 2:13 pm    Post subject: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
Was reading in a earlier forum that someone had used a rad. from a Honda Civic, said it worked fine. I was wondering what they used to make the inlet and outlet hoses fit, because the rad, is 1 1/8 in and out. The 77 is 1.5 in 1.75 out. Not sure how to make this work? Any help would be great Thanks.
Soilfarmer77
PostPosted: Wed Dec 12, 2012 2:46 pm    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
I'm running an electric pump, so I just removed the thermostat housing and water pump and welded up new plates/covers with 1 1/8 outlets. I lucked out and found hoses that worked at the parts store.
showdown
PostPosted: Wed Dec 12, 2012 2:52 pm    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
would this rad. keep it cool for it size.
830 man
PostPosted: Wed Dec 12, 2012 4:38 pm    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
I know of a guy running one on a 4010 jd and it seems to work fine for him. No longer than it will be running down the track i dont foresee any problems.
Soilfarmer77
PostPosted: Wed Dec 12, 2012 4:48 pm    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
Honestly, I'm still building my tractor. However, my thoughts are that if the radiator was built to cool a 150-200hp (or more) car, it should be more than enough to cool my 100hp tractor, especially the way I'm going to be using it.
johns
PostPosted: Thu Dec 13, 2012 4:36 am    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
Whats the dimensions of your original rad?
showcrop
PostPosted: Thu Dec 13, 2012 11:53 am    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
I used gray plastic barbed adapters from the hardware store, and went to my local auto parts and perused the rack for a hose with the right bend.
Jim F.
PostPosted: Fri Dec 14, 2012 7:19 am    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
Just so you dont move the coolant through too fast. I removed the thermostat and installed a plate with two 1/2" holes drilled in it to limit the flow.
showdown
PostPosted: Fri Dec 14, 2012 7:57 am    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
I would think the 1/18 in. hoses would slow the flow by themselves?
showcrop
PostPosted: Fri Dec 14, 2012 8:17 am    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
showdown wrote:
(quoted from post at 08:57:09 12/14/12) I would think the 1/18 in. hoses would slow the flow by themselves?
I think that it is assumed that you would be using 1.5 and 1.75 hose adapted down close to the radiator.
showdown
PostPosted: Fri Dec 14, 2012 2:39 pm    Post subject: Re: Honda Civic Rad. in 77??? Reply to specific post Reply with quote
Hey Showcrop I was unable so far to find the right adapters in the hardware, everthing goes by the 1/4 in, the rad. on the civic is 1/8, so I have to get from 1 1/8 to 1.5, and 1.75. haven't found any thing in the 1/8 size to use, any ideas. Thanks.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
