| Author |
Message |
kylemorley Regular
Posted: Wed Dec 12, 2012 2:43 pm Post subject: Is this wrong? How wrong? (trailer hitch setup) |
I needed to tow a trailer in a hurry, and didn't have one of those locks to keep the bar from rolling, so I just bolted the top link to the drawbar with a 3/4" bolt. Seemed to work fine, and has the advantage of preventing the drawbar from pushing/lifting up.
Seems too easy though. What am I overlooking?
| Back to top |
HCooke Tractor Expert
Posted: Wed Dec 12, 2012 2:57 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
As long as you are not towing a heavy load or going down hill I think you would be OK. |
| Back to top |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50434 Location: Lake of the Ozarks area of MO
Posted: Wed Dec 12, 2012 3:02 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
Well as long as your being careful it will maybe be ok. I have seen center links break and if that happens and the trailer is tail heavy you can be a dead man with a trailer hitch sticking out your chest |
| Back to top |
Switchflicker Regular
Posted: Wed Dec 12, 2012 4:02 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
What other arrangements would be safer to prevent the drawbar from moving up or down during the tow?
Sw |
| Back to top |
JMOR Tractor Guru
Posted: Wed Dec 12, 2012 4:30 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
| Switchflicker wrote: | (quoted from post at 20:02:24 12/12/12)
Sw | Top link is stronger than a pair of stay bars. I prefer the under belly draw bar myself, but don't know that it is safer. |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5872 Location: Myersville, MD
Posted: Wed Dec 12, 2012 4:32 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
Sw |
It's hard to tell from the picture but it looks like you have the OEM under axle clevis for a swinging drawbar. Might want to consider adding stay bars and a swinging drawbar. - made for just what you want to do.
TOH |
| Back to top |
Royse Tractor Expert
Posted: Wed Dec 12, 2012 4:33 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
If you stay with that I would make sure the PTO is off so you don't
bump the lever and try to lift it by accident.
It looks like you have a swinging drawbar hitch under the tractor.
Why not just add the drawbar and stay bars?
| Back to top |
Posted: Wed Dec 12, 2012 4:48 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
The arrangement above is exactly what I need. Thanks Royse.
Is that one store bought or home grown?
Sw |
| Back to top |
Posted: Wed Dec 12, 2012 4:54 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
| Switchflicker wrote: | (quoted from post at 20:48:02 12/12/12)
Sw |
Buy used or make your own. The originals are quite pricey....
TOH |
| Back to top |
Posted: Wed Dec 12, 2012 4:56 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
Sw |
The stay bars and drawbar can be bought from this site, or your local TSC, etc.
They were OEM equipment on some of the N's, but may have been an option??
Here's another version that I like better, because it leaves your
3pt hitch free to use, but it does add more pieces and cost.
| Back to top |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 253 Location: central Mass
Posted: Wed Dec 12, 2012 5:18 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
I used a receiver hitch blank welded to a plate and bolted it in place of the swinging drawbar hitch. That way I can use any number of different ball mounts and towing arrangements. |
| Back to top |
Posted: Wed Dec 12, 2012 5:32 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
| Royse wrote: | (quoted from post at 20:56:33 12/12/12) | Switchflicker wrote: | (quoted from post at 20:48:02 12/12/12)
Sw |
I do not think you can buy the older Dearborn style swinging drawbar or hitch new. A complete SDA6 aftermarket drawbar kit is roughly $125 and replaces the OEM style hitch used on the 8N with the improved design used on the NAA and later tractors.
TOH
| Back to top |
Posted: Wed Dec 12, 2012 5:54 pm Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
Thanks for pointing that out TOH.
I didn't mean to say you could buy the OEM parts, I just meant that
similar ones were readily available. I didn't make that very clear.
Like 55deere70 mentioned, I also use what was a bumper mounted receiver,
flipped upside down and bolted to the top of a 13 hole drawbar on one of my tractors.
I welded on flat stock sticking upright to meet the top link.
I then use the 3pt to lower the hitch, back under the trailer tongue and lift it.
I use it to move my boats and empty trailers around the yard for mowing etc.
I wouldn't recommend that for much weight, but it's nice to be able to move
light stuff around the yard without climbing on and off every time. |
| Back to top |
Posted: Thu Dec 13, 2012 6:08 am Post subject: Re: Is this wrong? How wrong? (trailer hitch setup) |
Thanks for your responces fellas
Sw |
| Back to top |
