| Author |
Message |
longear Regular
Posted: Thu Dec 13, 2012 7:46 am Post subject: ford 3000 |
I am going to look at a ford 3000 to buy.
anything I should look for?
It is gas and has a ford loader.
Thanks in advance. |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12430 Location: Twin Cities
Posted: Thu Dec 13, 2012 8:17 am Post subject: Re: ford 3000 |
Looking back at your earlier posts it appears that you are more of a Farmall man.
But a tractor is a tractor so I assume you know to look at tires, tin, paint, leaks, cracks, welds, smoke and to listen for knocks or rattles.
First off you Never trust the hours on the tach on one of these as they were prone to fail early.
Second what tranny does it have?
They came with 4,6,8 speeds with or W/O live PTO.
They also came with Select O Speed trannys - the worlds first powershift in a tractor. Others here can add more about the merits or demerits of the SOS.
Power steering is a big plus as is LPTO.
Some guys prefer diesels. Others are very happy with gassers.
They are great, small tractors. Known to be very reliable and parts are reasonable and relatively easy to find.
Post a little more info on it such as price, etc and some decent pictures if you can.
We can offer more and better replys then. |
| Back to top |
longear Regular
Posted: Thu Dec 13, 2012 9:22 am Post subject: Re: ford 3000 |
[quote="Ultradog MN"](reply to post at 17:17:19 12/13/12) [/quote]
It has the 8 speed tranny
i had a 4000 with that sos and never liked it.
guy says $5000 for it photos he sent look good.
I do prefer gas. |
| Back to top |
souNdguy Tractor Guru
Posted: Thu Dec 13, 2012 9:23 am Post subject: Re: ford 3000 |
ditto what ud said.
things to look at on a gasser are to see if the fuel system is cobbled up.. if it still has the oe holley carb or a zenith.. how the hyds for the laoder are run.. etc.
post back |
| Back to top |
ditto what ud said.
post back |
| Back to top |
Billy NY Tractor Expert
Seeing it has a loader, you can check the front axle pivot pin for excess wear, given its likely an ag/rowcrop front end. |
| Back to top |
Shetland Sheepdog Tractor Guru
Joined: 28 Oct 2008 Posts: 7001 Location: New Boston, NH, USA
Posted: Thu Dec 13, 2012 4:04 pm Post subject: Re: ford 3000 |
First sign of loader abuse will be a curve in the front axle radius rods! |
| Back to top |
Posted: Thu Dec 13, 2012 6:23 pm Post subject: Re: ford 3000 |
$5K is reaching the upper limit on these things.
It had better be pretty nice for that and either have PS, a rebuilt engine plus live PTO and pretty good tires.
Can you post the pictures?
Or email me and I will post the photos.
We like to pick apart the wares of other sellers here and will help you if we can. |
| Back to top |
longear Regular
Posted: Fri Dec 14, 2012 4:33 am Post subject: Re: ford 3000 |
[quote="Ultradog MN"](reply to post at 03:23:38 12/14/12) [/quote]
http://pittsburgh.craigslist.org/grd/3465929527.html
see if this link works
Thanks for all the replies |
| Back to top |
Posted: Fri Dec 14, 2012 5:17 am Post subject: Re: ford 3000 |
Not a bad looking tractor.
Figure $500 for the pie weights and $1000 - $1200
for the loader, now the tractor itself is in the $3300-$3500 zone which is about right. Seller might knock off a bit too.
I think it warrants closer inspection. |
| Back to top |
TMo Regular
Posted: Fri Dec 14, 2012 8:46 am Post subject: Re: ford 3000 |
Don't get burned like I did on a Ford 4000 gasser
I bought. Original Holley Carb was a mess. The
tractor had a lot of blow-by. I should have
compression tested it right on the spot, only
would have taken very little time, instead of
buying it and finding out later that it had a bad
cylinder. So really check it out good. Take a
mechanically inclined friend with you to help
inspect it too.
It can get pretty pricey to improve that machine
just in tires and carburetor alone. |
| Back to top |
longear Regular
Posted: Fri Dec 14, 2012 12:46 pm Post subject: Re: ford 3000 |
is the only way to test the blow by with a compression test? |
| Back to top |
longear Regular
Posted: Tue Dec 18, 2012 7:10 pm Post subject: Re: ford 3000 |
I went and looked at it.
It has power assist steering.
Not a live pto.
no major leaks
one pretty new rear tire.
tin is all straight.
starts and runs as it should
Loader very strong.
only bad things I could say is the paint is ugly and the rear tires are not loaded.
I did talk him down a bit. (not quite enough for me to commit yet)
| Back to top |
longear Regular
Posted: Mon Jan 21, 2013 5:23 am Post subject: Re: ford 3000 |
I went and bought it. Got it for $3000. did I do ok? |
| Back to top |
Pops1532 Regular
Posted: Mon Jan 21, 2013 7:56 am Post subject: Re: ford 3000 |
| longear wrote: | | (quoted from post at 13:23:10 01/21/13) I went and bought it. Got it for $3000. did I do ok? |
I'd say you have exceptional negotiating skills to talk him down 40%. |
| Back to top |
