| Author |
Message |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12437 Location: Twin Cities
Posted: Thu Dec 13, 2012 8:00 am Post subject: FordFarmer |
Here's one of those tractors we were talking about.
4200 NF Gas SOS on Ebay
| Back to top |
souNdguy Tractor Guru
Posted: Thu Dec 13, 2012 9:18 am Post subject: Re: FordFarmer |
too bad that wasn't in the tri-quad state area.. I'd seriously consider it..  |
| Back to top |
Fordfarmer Tractor Guru
Joined: 12 Dec 2005 Posts: 6541 Location: Ladysmith, WI
Posted: Thu Dec 13, 2012 10:08 am Post subject: Re: FordFarmer |
Yeah, that's the one I mentioned the other day. Pretty nice looking for a 45 year old tractor. Complete with a series 10 front weight bracket.  |
| Back to top |
Vito Tractor Guru
Posted: Thu Dec 13, 2012 10:17 am Post subject: Re: FordFarmer |
Chris,
It's not that far from you should be a weekend trip.We consider VA. almost in the south.
Vito |
| Back to top |
Vito Tractor Guru
Posted: Thu Dec 13, 2012 10:35 am Post subject: Re: FordFarmer |
Chris,
Vito |
| Back to top |
Posted: Thu Dec 13, 2012 2:29 pm Post subject: Re: FordFarmer |
if it was georgia, alabama, or mississippi, or even lousiana.. I'd do it.. |
| Back to top |
Posted: Thu Dec 13, 2012 2:46 pm Post subject: Re: FordFarmer |
You sure?
I know you'd really like a 3 cyl gasser.
And you've been flirting around with buying a jerk o matic for a while.
This would be a great candidate to kill two birds with one stone. |
| Back to top |
Posted: Thu Dec 13, 2012 2:48 pm Post subject: Re: FordFarmer |
And it's another NF... he's just gonna have to give in and go get it... |
| Back to top |
Posted: Thu Dec 13, 2012 3:04 pm Post subject: Re: FordFarmer |
i have been wanting one of those acursed trannies. and it's a trike.. though it is a flat deck..  |
| Back to top |
Posted: Thu Dec 13, 2012 3:05 pm Post subject: Re: FordFarmer |
don't think it isn't tempting... if a similar one popped for sale a lil farther south.. it might follow me home..
for instance.. a gasser 5000 NF.. I might have to drive for that one..  |
| Back to top |
showcrop Tractor Guru
Posted: Thu Dec 13, 2012 4:35 pm Post subject: Re: FordFarmer |
| soundguy wrote: | (quoted from post at 16:05:37 12/13/12) don't think it isn't tempting... if a similar one popped for sale a lil farther south.. it might follow me home..
Hey Chris, don't forget that those row crop 4000s and 5000s can be easily converted from wide to narrow. |
| Back to top |
Posted: Thu Dec 13, 2012 4:50 pm Post subject: Re: FordFarmer |
is it as simple as a pedistal change?
are the pedistals the same among them?
the NF later models are just so rare around here.. never see them.. an odd 6000 now and then.. etc.. |
| Back to top |
Posted: Fri Dec 14, 2012 6:17 am Post subject: Re: FordFarmer |
I believe it is that simple. The 4200 has it's own wide front axle, but the 5200 and 7200 (and '76 66/7600 RC's) share the same wide axles. Don't know without checking p/n's, but I -think- they all use the same NF pedistal. May even be the same as the prior RC's.
Any time you get a '65-up RC, it will be a flat deck. |
| Back to top |
Tony Jacobs Long Time User
Posted: Fri Dec 14, 2012 6:51 am Post subject: Re: FordFarmer |
Hello Chris , I used to know where there was TWO single wheel fronts for the 5000 , if you are interested I can check to see if they are still there then you would not be limited to just a narrow front , you could grab a wide front and convert it yourself . Thanks Tony |
| Back to top |
Posted: Fri Dec 14, 2012 7:49 am Post subject: Re: FordFarmer |
| soundguy wrote: | (quoted from post at 17:50:08 12/13/12) is it as simple as a pedistal change?
Knowing that you are not a purist, a Farmall pedistal nearly bolts right up. |
| Back to top |
