Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
MF152 Hydraulic Filter Location
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
Gerard Morris
PostPosted: Thu Dec 13, 2012 8:23 am    Post subject: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Hi. I have a 2WD MF152S and the three point lift started to go very slow (still plenty of force) and now will not lift. On investigation, the oil was low and I have filled it up but still no joy. I expect that the filter may be clogged (fair assumption ?). I have the user manual that points to a variety of places but not one that seems to apply to my variant. Does anybody have any idea where I may find it ?
I have done a search on the forum and also the picture gallery and could not find a similar subject to 152 so I am sorry if this has been addressed before.
Many thanks.
samn40
PostPosted: Thu Dec 13, 2012 9:29 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Your tractor is a Landini, badged as a Massey, Sorry but I have not worked on any of them and don't have an answer for you. Someone on here may now be able to help if they have a Landini based Massey.
Sam
Phil Tibbetts
PostPosted: Thu Dec 13, 2012 9:30 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Hydraulic filter is in side the transmission case. It should be accessible from the cover on the left side of the transmission which has the PTO engagement lever. You will need to drain some of the oil before removing the cover.
DavidP, South Wales
PostPosted: Thu Dec 13, 2012 9:58 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Hi Gerard,
There are three versions of the hydraulic pump fitted. The filter is in essentially the same place at the rear of the pump but access is different.
If your tractor is a later one look first on the underside of the rear centr housing, roughly on a line from the transmission dipstick but on the underside.
You may see a triangular plate held to the casing by three nuts or bolts. Drain the transmission and remove the plate. Inside you will find a spring clip and then a nut. Remove both and the filter will drop out.
If you don't have the plat access can be gained through the left hand side-cover. This however will depend on what equipment is fitted such as IPTO or auxillary pipework,
Assuming you don't have eithe and you have removed the cover you should find that the top of the filter is wired to the backplate of the pump. Cut the wire and use a small pair of pliers to undo the butterfly on top. Try and lift the complete assembly out as one. You will have the top cup, filter and bottom cup. There is a thin section O ring which normally stays on the pump. Ensure that it is not lost. Clean or renew the filter. If you don't have proper locking wire use a domestic electricalwire strand (cooker cable). Twist the wire ends after threading through the butterfly and backplate. Be careful as there are many potentially sharp edges on components around the filter.
Replace the cover and refill with oil.
If you have IPTO or aux pipework it may be necessary to remove the cover.
DavidP, South Wales
PostPosted: Thu Dec 13, 2012 10:01 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Hi Sam,
My AGCO parts access shows the conventional Ferguson pump fitted with either the older vertical filter for access through the side cover or the usside down one for access through the triangular plate if a later tractor.
DavidP
samn40
PostPosted: Fri Dec 14, 2012 12:44 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
David, I may be wrong, but Gerard says he has looked at other topics on the forum and with no joy. Now i know we both have explained finding the filters in older and more modern MFs as we know them. So I am assuming if the filters are not where we know then his tractor is the Landini/MF 152S.
I know the tractor you are thinking about....The French built MF152, but to my knowledge it was not built as a 152S. Instead the 152S had the styling of the 200 series or maybe even the later 300 series.
I have just done a yahoo images search, and the MF152S does indeed look different to our conventional MF tractors.
Sam
Gerard Morris
PostPosted: Sat Dec 15, 2012 11:00 am    Post subject: Re: MF152 Hydraulic Filter Location Reply to specific post Reply with quote
Thanks guys, a really helpful forum. However it would probably be more helpful if I supplied the correct information ! I actually have a 154 !
I think it is a Landini, as suggested, as it has a made in Italy plate.
The PTO control does not mount on the side under the seat like it does on the MF135 but is on a long thin lever that goes out through the back bulkhead.
There is a plate with 6 bolts under the gearbox (Shown in the far right hand of the attached photo). Do I guess that this is going to be the hiding filter"s place ?
Before I drain and drop this off, does a complete lack of pressure and no engine response one moving the levers point to a blocked filter or something more serious ?
Thanks again for all your help.
