9N loader identification
Matt Reichenberger
PostPosted: Thu Dec 13, 2012 10:03 am    Post subject: 9N loader identification Reply to specific post Reply with quote
I have recently purchased a loader for my 9N project. I looks like someone did a little hacking on it and the data plate was painted over. Does this like any make and model number that some one might have? Or know which one it is? The front mounts were poorly fabricated by someone, not the originals. I would like to get the dimensions or drawings of the right ones.
TheOldHokie
PostPosted: Thu Dec 13, 2012 10:15 am    Post subject: Re: 9N loader identification Reply to specific post Reply with quote
Matt Reichenberger wrote:
(quoted from post at 14:03:09 12/13/12) I have recently purchased a loader for my 9N project. I looks like someone did a little hacking on it and the data plate was painted over. Does this like any make and model number that some one might have? Or know which one it is? The front mounts were poorly fabricated by someone, not the originals. I would like to get the dimensions or drawings of the right ones.
Looks like a Wagner WM4. You can find the Wagner WM4 Manual on the N Tractor Club site. I make front hangers that will work with your loader. The WM4 hanger had a pedestal welded to the front for mounting the pump, I can provide somoething similar but not an exact suplicate - I'd like to think mine is better Wink Feel free to call me if you'd like more information.
Dearborn/Wagner Loader Brackets
TOH
oldhokie@verizon.net
301.655.0631
TOH
Matt Reichenberger
PostPosted: Sat Dec 15, 2012 8:51 pm    Post subject: Re: 9N loader identification Reply to specific post Reply with quote
It looks like the part that would attach to the three holes up front has been cut off. I have a good idea of what it should look like. I should be able to manage to make something with my welder and plasma cutter. Thanks for the help.
Matt Reichenberger
PostPosted: Sun Dec 23, 2012 10:40 pm    Post subject: Re: 9N loader identification Reply to specific post Reply with quote
I recieved the manual but it looks like the former owner cut off the part of the loader that mounted to the front. The mount that came with it when I bought it fits between the engine and the front axle cradle. I may need to bend some pipe and fix the loader just to mount it corectly. The pump also doesn't seem right. instead of six spline it has 12.
TheOldHokie
PostPosted: Mon Dec 24, 2012 3:45 am    Post subject: Re: 9N loader identification Reply to specific post Reply with quote
(quoted from post at 02:40:18 12/24/12) I recieved the manual but it looks like the former owner cut off the part of the loader that mounted to the front. The mount that came with it when I bought it fits between the engine and the front axle cradle. I may need to bend some pipe and fix the loader just to mount it corectly. The pump also doesn't seem right. instead of six spline it has 12.
The 12 spline shaft and modifications suggest it has been hacked to fit a different model tractor.
TOH
