| Author |
Message |
Jess R Regular
Posted: Thu Dec 13, 2012 10:28 am Post subject: farmall h build |
Im looking for ideas for my farmall H I would like to use the H block I was wondering what combinations people are using I want to try and get 50+hp I will be runing 3mph at 3500lb class thank you guys in advavance. |
| Back to top |
Tim Yates Regular
Posted: Thu Dec 13, 2012 2:42 pm Post subject: Re: farmall h build |
Take out the sleeves and run custom pistons at 3.75" bore. Stroke to 5.5" or 5.75". You can use stock rods and shold come up to approximately 80 to 85 horse power and be reliable. Shoot for 12.5 to 13 to 1 compression. Cam ground by Bullet , good 300/350 head . |
| Back to top |
Tim Yates Regular
Posted: Thu Dec 13, 2012 2:44 pm Post subject: Re: farmall h build |
You can run a good set of custom pistons with a good dome to raise the compression and stock stroke with a good 300 head will get you over 50 hp. |
| Back to top |
Jess R Regular
Posted: Thu Dec 13, 2012 5:31 pm Post subject: Re: farmall h build |
Thanks for the info is there alot of block grinding to fit the 5.5 stroked crank thanks again. |
| Back to top |
tuckerMAX New User
Posted: Thu Dec 13, 2012 7:50 pm Post subject: Re: farmall h build |
Yes. At 5.125 you have to take the webbing out. Grind the neck out of the oil galley just shy of breaking thru, and cut the cam down to 1/2" thick. With an untouched stock.rod. not to mention small.areas on the pan rail. |
| Back to top |
H-66 Regular
Posted: Fri Dec 14, 2012 3:08 am Post subject: Re: farmall h build |
You can take quite a bit off the stock rod for clearance so you don"t need to cut so far into the oil galley. Also cut flats in the cam so you keep it strong. 1/2" diameter on the cam is pretty small. |
| Back to top |
ss409 Regular
Posted: Fri Dec 14, 2012 5:34 am Post subject: Re: farmall h build |
if you cut the rods just right, use a 350 IH rod journal, not a H journal, you can do 5.75 with only notching the cam and the bottom of the cyl walls, and not touch the webbing, or oil gallery at all. good luck. |
| Back to top |
tuckerMAX New User
Posted: Fri Dec 14, 2012 9:01 am Post subject: Re: farmall h build |
ss409 is right, Youd be better off to put some effort in the rods. |
| Back to top |
RichB Regular
Posted: Fri Dec 14, 2012 2:32 pm Post subject: Re: farmall h build |
DOMES
| Back to top |
Jess R Regular
Posted: Fri Dec 14, 2012 5:50 pm Post subject: Re: farmall h build |
Just wondering who made your pistons looks good. |
| Back to top |
Nick in MD New User
Posted: Fri Dec 14, 2012 8:12 pm Post subject: Re: farmall h build |
RICHB- where did you get those pistons. what size are they? |
| Back to top |
RichB Regular
Posted: Tue Dec 18, 2012 7:54 am Post subject: Re: farmall h build |
Aries 3.80 bore no sleeve in block. |
| Back to top |
