9N identification help
gtwist
PostPosted: Thu Dec 13, 2012 2:32 pm    Post subject: 9N identification help Reply to specific post Reply with quote
Recently picked up what is MAYBE a 9N. Serial number is 9N 154023. According to pictures that are suppose to help identify, the bolt pattern for the front and rear rims is different from the pictures of the 9N, look more like the 8N.
Hope that"s half clear. Thanks for any help.
Den N Ms
PostPosted: Thu Dec 13, 2012 2:41 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
gtwist ,Check out Smith's Great Ford tractor site.
Smith
1951 8N
PostPosted: Thu Dec 13, 2012 2:44 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
You probably have a Ford 8N with a 1944 Ford 2N engine. Are you sure that it has a 9N before the serial number and that it's not an 8N?
Den N Ms
PostPosted: Thu Dec 13, 2012 3:01 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
gtwist ,Does it have a 3 speed or a 4 speed transmission?
souNdguy
PostPosted: Thu Dec 13, 2012 3:14 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
all N enginmes interchange.. rate the machine by trans.. that's a big difference between 9/2 and 8n..
old
PostPosted: Thu Dec 13, 2012 5:29 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
All 9N and 2N the serial number starts with 9N so do not let hat throw you. If it has a 4 speed but that serial number you have a mutt which is a tractor made from 2 or more dead ones. If it has a 3 speed then it is a 2N
gtwist
PostPosted: Fri Dec 14, 2012 1:15 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
I checked all the items to check that SMITH's recommended. The SN does start with a 9N with stars before and after number, 4 speed, freeze plug, grille has the up and down bars with the 4 bars running up and down in the center. Most things indicate it is an 8N that probably has had a 9N motor in it????. Engine stuck and pretty rough overall, probably part it out eventually after CHRISTmas.
Thanks for all your help and I wan to wish everyone on this site A Merry CHRISTmas.
1951 8N
PostPosted: Fri Dec 14, 2012 1:43 pm    Post subject: Re: 9N identification help Reply to specific post Reply with quote
What you have is a Ford 8N with a Ford 2N engine. Serial numner 9N154023 makes the engine from a 1944 Ford 2N.
