| Author |
Message |
Deere power 53 Guest
Posted: Sat Dec 15, 2012 12:59 pm Post subject: Flywheel |
Will a 70 john deere diesel flywheel work on a 720 diesel john deere? My 720 has play in the flywheel and was wondered if I could use anything to shim it up and make it tight. The person before me must have run it loose. I would like to use what I have Thanks again for any help. |
| Back to top |
Mike N Mo Long Time User
Posted: Sat Dec 15, 2012 1:23 pm Post subject: Re: Flywheel |
The parts book shows both 70/720 diesels use the same flywheel, AF2194R. Mike |
| Back to top |
Posted: Sat Dec 15, 2012 5:27 pm Post subject: Re: Flywheel |
Thanks Mike I know where I can get one off of a 70 that has been sitting for a long time and wanted to try and use that flywheel. |
| Back to top |
Posted: Sat Dec 15, 2012 5:39 pm Post subject: Re: Flywheel |
Just looked at my number on my flywheel and it was F1913R was that still for the 720 or could someone have put the wrong flywheel on it? |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23636 Location: in front of computer
Posted: Sat Dec 15, 2012 7:44 pm Post subject: Re: Flywheel |
Install a taper-loc flywheel.
Some time or other some slob worked on the tractor without a torque wrench. They either under torqued the flywheel bolts and let the flywheel slide. Or they over torqued the flywheel bolts and stretched the bolts which reduced the clamping force.And the flywheel slid.
So for the lack of of a few minutes and some care. The crank and flywheel are ruined. |
| Back to top |
Posted: Sat Dec 15, 2012 8:01 pm Post subject: Re: Flywheel |
The parts book shows that an FR2194R is the flywheel assy, consisting of a F1913R flywheel plus ring gear. Mike |
| Back to top |
gtx1967jewison Tractor Expert
Posted: Sun Dec 16, 2012 10:47 am Post subject: Re: Flywheel |
It wont work for long if at all. Yhe crank is worn now so a taperloc is the only solution short of an nos crank & perfect flywheel. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
