Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
fuel needed?
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
Farmall m 421
PostPosted: Sun Dec 16, 2012 8:06 am    Post subject: fuel needed? Reply to specific post Reply with quote
Looking at building a 421 m. Gonna have 12:1 compression. 450 lp head. 1920 high idle. Cammed for max torque about 1500. Typical 421 type build.
What type/octane fuel will I need for this type of engine? What do you guys recomend? VP110? Q16? Something else?
buickanddeere
PostPosted: Sun Dec 16, 2012 11:19 am    Post subject: Re: fuel needed? Reply to specific post Reply with quote
What if any quench in that engine combustion chamber? Are you planning on 25-35 thou of cold clearance between the piston and head? That will increase power and reduce detonation .
The cam duration can vary the compression pressure from requiring fuel from 87 to 115 octane . Tell you cam grinder what you have as a combo and they will grind to match.
Farmall m 421
PostPosted: Sun Dec 16, 2012 5:52 pm    Post subject: Re: fuel needed? Reply to specific post Reply with quote
A cam that would allow me to run 87 octane fuel would have overlap to the point that it would barely even run at 1500 rpm. If I want max torque at 1500 then I am going to have short duration and very high cylinder pressure. I want to know if I can run something in the 100-105 octane range, 110, or do I need something better like Q16? 87 aint gonna do for this.
ss409
PostPosted: Sun Dec 16, 2012 7:32 pm    Post subject: Re: fuel needed? Reply to specific post Reply with quote
110 did just fine at 300psi cranking psi, under full load, at 180 degree temp for 3 minutes on dyno.
Farmall m 421
PostPosted: Mon Dec 17, 2012 2:48 am    Post subject: Re: fuel needed? Reply to specific post Reply with quote
Thanks. What brand? VP110 or something else?
Superih
PostPosted: Mon Dec 17, 2012 5:19 am    Post subject: Re: fuel needed? Reply to specific post Reply with quote
Farmall m 421 wrote:
(quoted from post at 09:06:44 12/16/12) Looking at building a 421 m. Gonna have 12:1 compression. 450 lp head. 1920 high idle. Cammed for max torque about 1500. Typical 421 type build.
Any 110 will run fine. You do not have to worry about quench or cold clearance as the pistons must sit below the deck at top dead center to set static compression at 12:1.
ss409
PostPosted: Mon Dec 17, 2012 7:36 am    Post subject: Re: fuel needed? Reply to specific post Reply with quote
vp works fine. you was talking about cams there,,,, i dare ya to start with a 450 cam grind. if ur turning 1500 n under rpm, in my experiences, the 450 cam grind did very good in my engine. itll lug clear down to under 1000rpm n still chug out triple digit power. try it as a baseline n work ur way up.
Farmall m 421
PostPosted: Mon Dec 17, 2012 9:09 am    Post subject: Re: fuel needed? Reply to specific post Reply with quote
Do you have the stock 450 cam specs?
buickanddeere
PostPosted: Mon Dec 17, 2012 1:15 pm    Post subject: Re: fuel needed? Reply to specific post Reply with quote
What do you mean quench doesn't matter?
If you take a little extra time and care instead of just slapping
an engine together. Keeping the quench at 25-35 thou will
reduce the engines tendency to suffer detonation. The engine
will also make more power due to the improved combustion
chamber turbulence and mixing.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
