| Author |
Message |
Johnny Stricklin New User
Posted: Sun Dec 16, 2012 9:51 am Post subject: hydraulics |
Drained all fluid.Put new fluid in.My lift still will not work.Need help.Thanks. |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5914 Location: Myersville, MD
Posted: Sun Dec 16, 2012 10:14 am Post subject: Re: hydraulics |
| Johnny Stricklin wrote: | | (quoted from post at 13:51:38 12/16/12) Drained all fluid.Put new fluid in.My lift still will not work.Need help.Thanks. |
I assume it's a 9/2/8N. What doesn't work about the lift? Have you done anything in the way of diagnostics?
TOH |
| Back to top |
Posted: Sun Dec 16, 2012 3:20 pm Post subject: Re: hydraulics |
Its an 8n.Haven't took inspection side plate off.Tractor set outside for over a year without being started.It was full of water in tranmission.It was working when I parked it.Put 90 wt.gear oil in.Worked lift arms up by hand.Have I got maybe a stuck valve in pump? |
| Back to top |
Posted: Sun Dec 16, 2012 3:41 pm Post subject: Re: hydraulics |
| Johnny Stricklin wrote: | | (quoted from post at 19:20:30 12/16/12) Its an 8n.Haven't took inspection side plate off.Tractor set outside for over a year without being started.It was full of water in tranmission.It was working when I parked it.Put 90 wt.gear oil in.Worked lift arms up by hand.Have I got maybe a stuck valve in pump? |
It could be anything - you will have to start looking. Start by taking the inspection cover off and make sure the control linkage is attached and operating the control valve. You are going to need a shop manual.
TOH |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50680 Location: Lake of the Ozarks area of MO
Posted: Sun Dec 16, 2012 4:01 pm Post subject: Re: hydraulics |
Sat for over a year with water in the system not good. If your where it gets cold you could well have broken parts from ice or you may have stuck valves or other such thing. Always best to pull the inspection plate before doing much else so as to know what is really going on |
| Back to top |
Posted: Sun Dec 16, 2012 9:15 pm Post subject: Re: hydraulics |
Thanks for info.Will start looking tomorrow.Thanks for your time and help.Will check back with you. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
