Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
AC WD45 Standard Piston
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
Clem McNure
PostPosted: Sun Dec 16, 2012 2:11 pm    Post subject: AC WD45 Standard Piston Reply to specific post Reply with quote
I have a wd45 which had stuck pistons in the engine. I removed them but two of them where pitted real bad andI need to replace them. It has standard 4 inch aluminum pistons with a deep dish in them. I can find replacements but the pistons are either flat top or has a concave top but not like the ones I removed. I was wondering if these can be used as long as I change all four out to be the same ?
JMS/.MN
PostPosted: Sun Dec 16, 2012 4:20 pm    Post subject: Re: AC WD45 Standard Piston Reply to specific post Reply with quote
Flat tops were standard in the WD. Original WD45 concave was the 'Power Crater' piston. Gave increased hp and better combustion. Should be no problem as long as all four are identical.
BushogPapa
PostPosted: Sun Dec 16, 2012 6:48 pm    Post subject: Re: AC WD45 Standard Piston Reply to specific post Reply with quote
Buy a complete Kit: Sleeves, Pistons, Rings, gaskets, Etc...
Might as well get a 4 1/8" Higher compression kit..costs the same, anyway..
I put a "Gas" D-17 kit in mine..7.4:1 Compression..Never had any problem..
Clean-out the water-Jacket out well and coat the bottom of it liberally with Non-Hardening Permatex.. Use the same Permatex, when installing the Sleeves...
I had already changed to 12V and Alternator..
6V would start it, but never would "Spin it over"..just turned one-cylinder-at-a-time...
Get a GOOD Valve Job done and increase the seat pressure of the Valve Springs..
While the engine is out...replace the engine clutch and be sure it has a 9 spring pressure plate..
Do these and she will stand Blue Flame and work with the front wheels off the ground in 2nd gear..
Ron..
Jerry Coulter
PostPosted: Mon Dec 17, 2012 9:08 am    Post subject: Re: AC WD45 Standard Piston Reply to specific post Reply with quote
The WD45 crankshaft has a longer stroke than the WD. Don't use flat top pistons with the long stroke crank unless you are building a puller tractor.
