| Author |
Message |
720deere puller New User
Posted: Sun Dec 16, 2012 5:36 pm Post subject: need more 720 gas HP |
Needing contact info or any info on increasing hp on a stock 720 gas, pulling in 8500 & 9500lb. classes. Any help would be greatly appreciated. |
| Back to top |
Josh Blackburn Regular
Posted: Sun Dec 16, 2012 6:41 pm Post subject: Re: need more 720 gas HP |
How much power are you looking for. I have a real nice set of lp pistons. They will be a quick and easy 10 hp they Look brand new or can do something more. 9892775366 |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23715 Location: in front of computer
Posted: Mon Dec 17, 2012 1:20 pm Post subject: Re: need more 720 gas HP |
Higher compression. Re-ground camshaft. Port and manifold matching. Blend and smooth casting flash and sharp edges from the inside of the ports. A professional 5 angle valve job by a race engine shop, not a valve job by Bubba . Dry air cleaner element . Propane intake and exhaust manifolds.
Will make an easy 75HP at pto rpm. |
| Back to top |
Dblair Tractor Expert
Posted: Mon Dec 17, 2012 1:35 pm Post subject: Re: need more 720 gas HP |
there was a post on this forum a couple years ago where a guy said he went to 77 hp with the addition of diesel pistons . take it for what it's worth could just be hear say . that's a 22 hp jump from stock . |
| Back to top |
Posted: Tue Dec 18, 2012 10:27 am Post subject: Re: need more 720 gas HP |
Maybe onto something? The gas and diesel used the same 6-3/8 inch stroke. The diesel bore is 125 thou larger at 6-1/8".
Must have required some high octane fuel, couldn't even guess the compression ratio.
720AF 4.9 to 1, 720gas 6.14 to 1 and 720LP 7.94 to 1.
Even the LP pistons are an 29% ratio increase over the gas. |
| Back to top |
Lee DePew Guest
Posted: Thu Dec 20, 2012 3:05 pm Post subject: Re: need more 720 gas HP |
how big of a stroker crankshaft would fit in a 720 gas was a propane tractor converted |
| Back to top |
jd b puller Tractor Expert
Joined: 07 Jul 2001 Posts: 3166 Location: North Carolina
Posted: Thu Dec 20, 2012 3:14 pm Post subject: Re: need more 720 gas HP |
Lee, as far as I know it's the same as a G/70 as far as how much you CAN stroke it.
Stroke + journal = 13.375" I'm sure someone has gone bigger, that's worked for me. |
| Back to top |
Lee DePew Guest
Posted: Thu Dec 20, 2012 3:31 pm Post subject: Re: need more 720 gas HP |
thank you for the info greatly appreciated!!!!! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
