| Author |
Message |
upnorthwi Regular
Posted: Sun Dec 16, 2012 5:50 pm Post subject: How to buy a rebuilt motor update |
I've never posted a picture on here, so hopefully you guys can get it.
The guy finally sent me a few pictures of the rebuilt motor that has been sitting for who knows how long. They think it had rings put in and the valves done, but no other information.
Other than the blue color, it looks like a Z 129 or 30 motor, the casting number looks right and the oil filter can is on the side.
He's wanting $300.
Looking at the pictures, what do you guys think?
If you bought this, would you trust it or what would you do with it so you have confidence?
Other than seeing a head gasket, I can't tell if anything was done with it.
And I can't tell if it's dirt or a crack by the distributor.
If the head was done, can it be trusted since the ports were not taped?
Suggestions? I'm not real knowledgeable here and don't want to make a mistake in either buying it or getting it ready for my tractor.
| Back to top |
DanP Regular
Posted: Sun Dec 16, 2012 6:03 pm Post subject: Re: How to buy a rebuilt motor update |
If it was me, if I would buy a gasket set for starters. Tear the engine down, inspect everything and put it back together. Replacing anything along the way that wasn"t witnin spec. If you are lucky, only gaskets and consumables will be needed. |
| Back to top |
Jason S. Long Time User
Posted: Sun Dec 16, 2012 6:19 pm Post subject: Re: How to buy a rebuilt motor update |
My first thought is, if it was rebuilt and then put in a shed and hasn"t been run any, why is it greasy back towards the flywheel? I think they may of had he head off of it but I have my doubts that it was fully machined and rebuilt and then set to the side. On the bright side if it has a good block and crank, it"s worth $300.00 |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9852 Location: Western Montana
Posted: Sun Dec 16, 2012 6:30 pm Post subject: Re: How to buy a rebuilt motor update |
Define rebuild!
Looks like Continenatl Z129 since the oil filter is external. Does it turn?
It could have had new sleeves and pistons and if the journals were OK it could have had new bearings put in and never left the bench. I can"t tell whether the pan was off but it would have had to if bearings were checked and/or replaced All I can see is that it looks like the head was off and my guess "rebuild" could mean a valve job.
If the head is good,and it turns, it"s worth $300 if it had a valve job. The real bad issue with the Z129 is block cracking and you can"t tell that unless you pull the head. |
| Back to top |
s19438 Long Time User
Posted: Sun Dec 16, 2012 6:57 pm Post subject: Re: How to buy a rebuilt motor update |
buying this engine would an absolute leap of faith. i'd offer 150 for it, maybe go 175 but no more. too, too many questions unanswered. |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Sun Dec 16, 2012 7:30 pm Post subject: Re: How to buy a rebuilt motor update |
First off... along Jason's train of thought... it is greasey where long run engines are greasey. If it was rebuilt, someone would have cleaned if not tanked it... so long ago they didn't invent tanks yet? the bolts on the timing cover... which looks odd at this angle, look like they never been removed, neither the oil filter etc etc..
If this was 'rebuilt, it was on the fast and cheap. Say like guys above- maybe a valve job a long time ago? Which technically isn't a 'rebuild' and... in my experience, if an engine wasn't run, for a few to many hours after a rebuild, the rings will sieze up again, being so new, dry and ripe for dew to make rust. I don't know about 300.... if you need an engine, and can get a refund if things don't pan out... otherwise scrap value for 500 pounds of iron... |
| Back to top |
Duner Wi Tractor Expert
Posted: Sun Dec 16, 2012 7:45 pm Post subject: Re: How to buy a rebuilt motor update |
If I were to buy it I would follow DanP's advice. |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 8:58 pm Post subject: Re: How to buy a rebuilt motor update |
Thanks DanP,
I have a feeling there wasn't anything done but a head. Interesting that the block is blue, the head bare and the valve cover red. Seems if it had a valve job the head would be blue as well as the cover. I'm going to offer $150 and see what he says and follow your advice, hoping it didn't over heat and is cracked. |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 9:02 pm Post subject: Re: How to buy a rebuilt motor update |
I was very disappointed when I got the pictures, glad I didn't drive all the way there to find that.
My feeling is like you said, the head was replaced and that's it. I also like how the block is blue, head bare and cover red. Seems pieced together.
I'm going to gamble and offer $150, pull it apart and hope it's not cracked. |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 9:07 pm Post subject: Re: How to buy a rebuilt motor update |
Well my definition sure doesn't match the picture.
That's why I asked for a picture before I made the trip. I asked the guy what he considered rebuilt since some people think replacing the gaskets is an overhaul.
It's obvious someone put a head on and that's it. I'm going to offer half, see what he says and hope it isn't cracked. |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 9:08 pm Post subject: Re: How to buy a rebuilt motor update |
I agree and just sent him an offer for half.
Thanks |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 9:12 pm Post subject: Re: How to buy a rebuilt motor update |
I agree with what everyone is saying.
I've offered him half. I think if he won't come down that much I'll ask for some sort of a guarantee that it's good.
But, I don't think he knows what was or wasn't done, so maybe he'll just do the $150. |
| Back to top |
upnorthwi Regular
Posted: Sun Dec 16, 2012 9:13 pm Post subject: Re: How to buy a rebuilt motor update |
Will do,
Thanks |
| Back to top |
Richard L Tractor Expert
Posted: Mon Dec 17, 2012 6:00 am Post subject: Re: How to buy a rebuilt motor update |
I am not sure but is that engine sitting on the flywheel? I would have liked it better if it had been sitting on the oil pan. It just seems as those pics. are not as they should be. |
| Back to top |
upnorthwi Regular
Posted: Mon Dec 17, 2012 6:27 am Post subject: Re: How to buy a rebuilt motor update |
Hi Richard,
Just as you see, sitting on the flywheel. He claimed it had been in a barn or shed for some time, then moved under a lean to. But with all the dirt on the front and only half of the pulley, I say it's been sitting that way awhile. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
