| Author |
Message |
Tom in MO Regular
Posted: Mon Dec 17, 2012 5:22 am Post subject: Where/How to Jack Up/Block Up Front of Tractor? |
Another Dumb Question: I want to change the spacing of the front wheels on my TO-20 - where/how do you jack up/block the front end, to get both wheels off the ground at once?
I have the Owner's Manual and the Shop Manual, but they both assume that everybody already knows how to do this. (In at least one picture, it looks like they're using the tractor jack that works off the lift arms.)
I have/can get floor jack, jackstands, 4x4, etc.
I did a quick search of the archives, both here and on the N Board, and it sounded like you block under the oil pan - that just didn't seem quite right to me.
I sure it's different, depending on what you're doing: removing the entire front axle, for example, as opposed to just changing the wheel spacings. |
| Back to top |
trac Long Time User
Posted: Mon Dec 17, 2012 5:42 am Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
No don't lift under oil pan on the 8N it's cast iron
it may be easier just to do one at a time.Look for
the front axle pivot point you should be able to get
it from there. |
| Back to top |
Dan S (NY) Long Time User
Posted: Mon Dec 17, 2012 9:20 am Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
I usually use a hydraulic jack under the front axle carrier when lifting the front. If I am only working on the wheels, I will then use jack stands under the axle on each side, otherwise I slide a stack of 4x8 timbers under the front of the transmission. I always put blocks around the rear wheels to prevent rolling.
Dan |
| Back to top |
Jeremy in DE Regular
Posted: Mon Dec 17, 2012 9:34 am Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
Sometimes you need to jack the entire front end up and support it. But when I've changed front wheel spacing I've found it easiest put a sturdy support (in my case a bottle jack on blocks) under the front axle support to take most of the weight and to act as a backup. Then a jack on one side that just catches the main axle member (but not the part you want to unbolt) to cock one side up a bit. Do one side at a time. This is how I did it. Likely someone else has a better way. |
| Back to top |
Tom in MO Regular
Posted: Mon Dec 17, 2012 9:52 am Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
Thanks, Guys.
I think Jeremy answered my question (even though I didn't ask it very well): it is indeed possible to jack up the center axle section on one side, to take the weight off of the wheel you're working on, and be able to move the axle extension on that side. |
| Back to top |
Boss Hog Long Time User
Posted: Mon Dec 17, 2012 2:39 pm Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
I usually cheat a bit - Out something heavy on the 3 point. (Like a rear mounted blade)
Makes it easier to jack the thing up. And I usually just jack one side up at a time. |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9852 Location: Western Montana
Posted: Mon Dec 17, 2012 4:47 pm Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
Jack up the front of the tractor using a pirece of 2x6 and a floor jack under the oil pan. |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 948 Location: West central Wisconsin
Posted: Mon Dec 17, 2012 6:50 pm Post subject: Re: Where/How to Jack Up/Block Up Front of Tractor? |
If you stick a floor jack under the bell housing it should lift the front end off the ground.
Bob |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
