Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
ck-40rear axle removal
Post new topic    Yesterday's Tractors Forum Index -> Oliver, Cletrac, Coop and Cockshutt
88-1175
PostPosted: Mon Dec 17, 2012 7:23 am    Post subject: ck-40rear axle removal Reply to specific post Reply with quote
i have the outside flange off and the nut on the inside off.cant seem to be able to remove the axle to get the bull gear out,is the axle held in by something else too....
Mike(NEOhio)
PostPosted: Mon Dec 17, 2012 6:47 pm    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
My manual says to loosen the bolts on the bearing cap and bump the wheel flange outward with a heavy bar. Then take the bolts out and continue bumping till the shaft comes out. The splines in the bull gear may be stuck, too.
P Heisey Harleysville,PA
PostPosted: Tue Dec 18, 2012 2:34 am    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
Make sure all is supported to eliminate all binding action. I usually have to use hydraulics to push the axles out of the bull gears.
Phil Heisey
215-256-8651
Mike(NEOhio)
PostPosted: Tue Dec 18, 2012 5:52 pm    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
Hey Phil,
Maybe you can explain this. On my E-4, one axle housing has the grease fitting up and the other is down. It looks like one was installed upside down with no place to bolt the foot plate. I've seen lots of them at shows and they are all that way. Did they originally come this way?
Mike
PostPosted: Wed Dec 19, 2012 2:27 am    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
Hi Mike,
The SAME axle housing trumpet....TG-9426 (early 40-50 with fixed std. axle) is used on either side. This is the way Cockshutt built most of their tractors.....35-40-50-GA-540-550-560-570-570S
The "30" tractor does have DIFFERENT trumpets on each side.
Phil
Mike(NEOhio)
PostPosted: Wed Dec 19, 2012 5:08 pm    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
Thanks, Phil
I could see that both trumpets were the same part. I always fiured somebody worked on it and put it back together wrong. It looks like it would fit either way. And that cutout at the trumpet end looks like it could be clearance for some sort of mounted equipment.
PostPosted: Wed Dec 19, 2012 5:31 pm    Post subject: Re: ck-40rear axle removal Reply to specific post Reply with quote
Hi Mike,
The curved out part of the trumpet is made to fit the rockshaft 3 point cylinder under the floor tread on clutch pedal side of the tractor.
Phil
