Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Serial Number Location on a 3 cyl. 2000
Post new topic    Yesterday's Tractors Forum Index -> Ford
Jim Wieringa
PostPosted: Mon Dec 17, 2012 2:43 pm    Post subject: Serial Number Location on a 3 cyl. 2000 Reply to specific post Reply with quote
Where is the location on a 2000 3 cylinder for the serial number?
Mike Groom
PostPosted: Mon Dec 17, 2012 3:52 pm    Post subject: Re: Serial Number Location on a 3 cyl. 2000 Reply to specific post Reply with quote
It's located on the flat horizontal portion of the casting on the right side of the engine where it joins the transmission,it should be a milled surface with the # on it. Hope this helps.
Sean in PA
PostPosted: Mon Dec 17, 2012 4:45 pm    Post subject: Re: Serial Number Location on a 3 cyl. 2000 Reply to specific post Reply with quote
It's stamped into the flat spot that faces upwards on the transmission bell housing just toward the rear of the tractor from the starter. There should be 3 numbers stamped into that flat spot. The first number should be the model number (not 2000, but a coded model number that says exactly which engine, PTO and transmission options the tractor had). The second number should be the Unit Number, or production code, which will tell you exactly what day the tractor rolled off the assembly line. The third number is the serial number and should start with a letter, either A, B or C, depending on which factory it was assembled at, followed by a 6 digit number.
If you're lucky, those same numbers might still be on a foil sticker on the under side of the right side hood panel as well. If that sticker's still there it will also have the production codes for the engine, transmission, hydraulic lift and hydraulic pump assemblies as well.
rd 2N in mo
PostPosted: Tue Dec 18, 2012 10:44 am    Post subject: Re: Serial Number Location on a 3 cyl. 2000 Reply to specific post Reply with quote
look here
Jim Wieringa
PostPosted: Tue Dec 18, 2012 2:40 pm    Post subject: Re: Serial Number Location on a 3 cyl. 2000 Reply to specific post Reply with quote
Thank you all, it has been very helpful. I now have the numbers I need to know what I have..
