| Author |
Message |
VicS Tractor Expert
Posted: Mon Dec 17, 2012 3:32 pm Post subject: Ferguson 50 engine build |
I am about like Eric, only dummer. I am going to try to make a Ferguson into a winning 3 to 4 mph puller in the 3500 to 4000 lb class for a friend. I think this engine is a Continental. Have just seen one pull at Princeton In. and this is it. We need to know if a head or intake will work from a bigger motor. Thanks Vic |
| Back to top |
CLIFF S Long Time User
Joined: 12 Jun 2005 Posts: 1101 Location: Cogan Station,PA
Posted: Mon Dec 17, 2012 5:59 pm Post subject: Re: Ferguson 50 engine build |
Vic
not this is much help but we had a guy that pulled 1 at our local pulls it done real well but it was stock!
congratulations on your win again at Tunica!
I hope someday I can come Pull
With you there!
Cliff S |
| Back to top |
VicS Tractor Expert
Posted: Mon Dec 17, 2012 8:17 pm Post subject: Re: Ferguson 50 engine build |
Thanks I went to Princeton In. The week before and did the best of my life. Won the 3500 and Pulled it out the door in the 4000 then just for a hoot entered the 6 mph and got second. So I figured my luck was over but the next week, got lucky again at Tunica. Yes you need to make it down. Great people and a great building. It is big enough Cale had his sled in the back (you can practice for $10 a hook anytime) also a scales. So when you get in line for your scales you should be within one weight of being right. Vic |
| Back to top |
bgoodyears New User
Posted: Tue Dec 18, 2012 7:19 am Post subject: Re: Ferguson 50 engine build |
Give me a call. I would love to hear what you have in mind for this build as I would like to do something very similar with a continental. 859.588.2433 |
| Back to top |
LCB Long Time User
Posted: Tue Dec 18, 2012 8:13 am Post subject: Re: Ferguson 50 engine build |
That 50 at princiton was stock also.They are conetal ehgines.I tougth a 65 engine would bolt in but he said not.There use to be a real good 65 pull in In. I would emagine that E Bloom would know who it was.I dont know how they compair to a 50 but if you can get weight down that would be the way to go. |
| Back to top |
VicS Tractor Expert
Posted: Tue Dec 18, 2012 3:05 pm Post subject: Re: Ferguson 50 engine build |
We have heard a 65 engine would bolt in. I looked on the specs page and the 65 is just 30 cu more. Those engines are high. have found a 133 like it has for 400. I"m thinking about just seeing how long a arm will swing inside with about a 1.8 crank-pin. Then see how big a sleeve will work with out moving the head bolts. A 85 is just 230 cu I think. That should be enough. Maybe we can make a 85 manafold work with a little tweaking! One thing about them they have a few good gear ratios. like your H. Sure missed you at Tunica. maybe next year. Vic |
| Back to top |
unstylish Regular
Posted: Wed Dec 19, 2012 9:57 am Post subject: Re: Ferguson 50 engine build |
Vic, I thought about this. I was going to try to put a 318 perkins 4 cyl (should bolt in, I THINK) into a 40 or 50... |
| Back to top |
VicS Tractor Expert
Posted: Wed Dec 19, 2012 4:25 pm Post subject: Re: Ferguson 50 engine build |
Is this engine found in a 410 or 510 Combine? thanks Vic |
| Back to top |
LCB Long Time User
Posted: Wed Dec 19, 2012 5:23 pm Post subject: Re: Ferguson 50 engine build |
410 had a 6 cylinder chev 290 510 had a 327 chev V8. |
| Back to top |
smokeshow Guest
Posted: Wed Dec 19, 2012 5:41 pm Post subject: Re: Ferguson 50 engine build |
Vic the 410 had the AD 4.302 perkins. Same as the 318 but a tad less stroke. I have the 302 in my coop. You have seen it pull. |
| Back to top |
VicS Tractor Expert
Posted: Wed Dec 19, 2012 6:22 pm Post subject: Re: Ferguson 50 engine build |
Thanks Guys. I've already learned quite a bit more about Massey's. My friend has bought a new 85 hp Massey. He thinks it has a 276 cu 4 cyl. Is this the same block. ps: it has a turbo. He called me yesterday and said, wouldn't get his new tractor today. The guy delivering it had forgot to check if the doors were shut, and the right one had dissapeared. SSo he hasn't got his new tractor yet. Vic |
| Back to top |
