Ford 3 pt disk question?
Wayne Wiseman
PostPosted: Mon Dec 17, 2012 6:03 pm    Post subject: Ford 3 pt disk question? Reply to specific post Reply with quote
I have a lift type Ford disk. The serial no. is 56970 and the model no. is LIFT-E.
Are the hub bearings a wood type or metal type?
Where can I purchase the hub wood blocks or metal type bearings. Hub bearings might not be the correct name but it is where the grease fittings are. Total of eight.
Royse
PostPosted: Mon Dec 17, 2012 6:37 pm    Post subject: Re: Ford 3 pt disk question? Reply to specific post Reply with quote
Wayne Wiseman wrote:
(quoted from post at 22:03:59 12/17/12) I have a lift type Ford disk. The serial no. is 56970 and the model no. is LIFT-E.
Google "ford lift-e disk" and select the .PDF in the first link.
Is this what you're working with? Can't post a link here.
Tim PloughNman Daley
PostPosted: Wed Dec 19, 2012 4:51 am    Post subject: Re: Ford 3 pt disk question? Reply to specific post Reply with quote
Wayne-
The Dearborn Lift Type E Disc Harrow uses wood bearings as did all Ford-Ferguson and Dearborn disc harrows made back then. There is a company that makes them but you will have to go the other Ford Tractor web site to get the info.
email me for more info if you don't know
Tim
