engine seals
Robert J Hampton
PostPosted: Tue Dec 18, 2012 4:01 am    Post subject: engine seals Reply to specific post Reply with quote
I have a AD3-152 how do I dertermine if it has the rope type main seal or lip type. I would like to know before tearing it down.
DavidP, South Wales
PostPosted: Tue Dec 18, 2012 9:12 am    Post subject: Re: engine seals Reply to specific post Reply with quote
Hello Robert,
In the UK the rope type was fitted up to engine number UA391044DL.
If you are not able to identify it by the engine number I do not think that you will be able to confirm which it is unless you split the tractor and remove the clutch and flywheel. Due to the lip on the backplate you will not be able to see the seal housing. Even if you took the sump off I do not think that a positive ID could be made.
DavidP, South Wales
Chris Gregory
PostPosted: Tue Dec 18, 2012 1:53 pm    Post subject: Re: engine seals Reply to specific post Reply with quote
Hello Robert, there are modern solutions which we have developed for older style engines to replace rope seals & later 2-piece rubber seals. Depending on quantity required there are two different design approaches which we use. This concept can be evolved to suit any older engines & should provide technically effective solutions for obsolete engine crankshaft seals.
EJ70
PostPosted: Tue Dec 18, 2012 2:05 pm    Post subject: Re: engine seals Reply to specific post Reply with quote
Come again?
DavidP, South Wales
PostPosted: Wed Dec 19, 2012 2:03 am    Post subject: Re: engine seals Reply to specific post Reply with quote
I thought I had missed something until I read EJ70's comment. What a load of waffle!. Sorry Chris but you clearly have no idea what you are talking about when it comes to the replacement of a Perkins tractor rear crankshaft seal.
DavidP, South Wales
Masseynut(Australia)
PostPosted: Wed Dec 19, 2012 12:53 pm    Post subject: Re: engine seals Reply to specific post Reply with quote
If you drop the sump as David has suggested, the semi-circle recess in the back of the sump will give you and indication as to which seal type you have.
If the recess where the "cork" sump seal sits is the same diameter as the front recess, the engine will be fitted with the rope type seals.
If the recess is much larger in diameter to the front semi-circle recess, it will be a lip-type seal arrangement.
Evan.
EJ70
PostPosted: Thu Dec 20, 2012 4:38 pm    Post subject: Re: engine seals Reply to specific post Reply with quote
I had to read it a couple times myself David. It also gave me a headache.
