Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
ford 4000 gas
Post new topic    Yesterday's Tractors Forum Index -> Ford
townsend2
PostPosted: Tue Dec 18, 2012 2:38 pm    Post subject: ford 4000 gas Reply to specific post Reply with quote
tractor shuts off when working and will not restart untill it sits for awhile any ideas on why thought vaper lock ran with cap loose and it still does it
Fordfarmer
PostPosted: Tue Dec 18, 2012 2:44 pm    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
3 or 4 cylinder 4000?
My first thought would be the ignition switch, if it's a 4-cylinder. Could also be a coil going bad, on either model.
souNdguy
PostPosted: Tue Dec 18, 2012 3:05 pm    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
the best way to figure out what's wrong is to actually DIAGNOSE it.
1, it helps us to know 2 cyl or 4. the 4 have a very basic fuel system.. the 3 are much mroe complicated with a pump, different routing and a cantankerous carb.
past that.
at moment of death and during restart attempts when it won't start. does it have spark? good spark?
if yes.. move on to fuel.. specifically fuel flow.. they won't run with an empty carb.
if it don't have spark.. hotwire coil.. if nada still.. check points, feel coil.. .. use ohm meter on connections with power unhooked to look for shorts, and if points open and close. check continuity on secondary and primary of coil.. check dizzy feed thur insulator.. make sure condensor is not shorting ( rare ) but happens.
post back
Larry NCKS
PostPosted: Tue Dec 18, 2012 5:08 pm    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
soundguy wrote:
(quoted from post at 18:05:40 12/18/12) the best way to figure out what's wrong is to actually DIAGNOSE it.
didn't ford made a 2 cyl 4000. Wink
View user's profile AIM Address
souNdguy
PostPosted: Tue Dec 18, 2012 5:45 pm    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
i hope / think everybody knows by now that I don't have a computer and instead get connectivity from small mobile devices that don't have real keyboards.
typo's are gonna happen.
Larry NCKS
PostPosted: Wed Dec 19, 2012 5:46 am    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
soundguy wrote:
(quoted from post at 20:45:48 12/18/12) i hope / think everybody knows by now that I don't have a computer and instead get connectivity from small mobile devices that don't have real keyboards.
I did not know that. How would I or everybody know that?
And yes . . . I knew it was a typo . . . but still think it's funny!
JMOR
PostPosted: Wed Dec 19, 2012 5:57 am    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
Larry NCKS wrote:
(quoted from post at 21:08:26 12/18/12)
I think they painted those 'green'. Arrow
souNdguy
PostPosted: Wed Dec 19, 2012 6:06 am    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
I've mentioned it many, many, many times over the last couple years.
My 'largest' machine is a netbook.. not even a large netbook.. it's one of the subcompact 'thin' ones about the size of a paperback book. Otherwise i'm on an iphone or similar other tablet or handheld device. None with real keyboards or mouse.. just the funny touch sensitive stuff. Even at 'work' our devices are ipads or that netbook i carry.
townsend2
PostPosted: Wed Dec 19, 2012 8:11 am    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
it is 3 cylinder and it had no spark put new coil on still did not start tractor sat for about an hour turned the key and it started
souNdguy
PostPosted: Wed Dec 19, 2012 9:18 am    Post subject: Re: ford 4000 gas Reply to specific post Reply with quote
ok.. 3 cyl. had no spark.
you changed coil.
then you say no start.. but you don't say if it had spark and did not start.. or did not have spark. if it had spark but no start.. look at fuel. if it did not have spark, and setting helps, then look at ignition switch. which is why i said to hotwire coil... it bypasses ignition switch.
go back and do the checks again, as I mentioned in my first post.
you have to be systamatic in troubleshooting. you can't take a list of 6 things, pick the 2 out you like, and forget the rest.
all or nada...
