| Author |
Message |
sixbales Regular
Posted: Tue Dec 18, 2012 3:24 pm Post subject: Ford 3600 won't shift into 4th/8th gear |
I"ve got a Ford 3600 with an 8 speed transmission. It will not shift into 4th/8th. I had the cover off a few days ago, and checked the detent (ball looked fine) - wouldn"t shift with detent ball/spring/plunger removed. The set screw is set well in its divot on the rail. With the engine running and clutch out I tried shifting and could hear a low-level growl.
I"ve concluded that there must be a misalignment at the shift collar. Maybe a bent fork.
What sayeth you Gurus?? |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Dec 18, 2012 3:44 pm Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
will it shift with the engine off?
when you shift it to 4th, then pull the cover.. does it look engaged? |
| Back to top |
sixbales Regular
Posted: Tue Dec 18, 2012 4:03 pm Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
Howdy Chris,
It will not shift into gear with engine on or off. I tried it with the engine on and clutch out to see if I could hear it grind - and it did grind. |
| Back to top |
Posted: Tue Dec 18, 2012 4:15 pm Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
shift it in and see how far it goes.. |
| Back to top |
sixbales Regular
Posted: Tue Dec 18, 2012 5:01 pm Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
The shift lever moves less than 1/4" from neutral to firm stop at 4th gear. |
| Back to top |
RodinNS Tractor Guru
Posted: Tue Dec 18, 2012 6:38 pm Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
My money would be on a bent fork... provided the shift lever is actually engaged in that rail.
Can you move the left rail rearward with a pry bar with the cover removed?
Rod |
| Back to top |
sixbales Regular
Posted: Wed Dec 19, 2012 3:43 am Post subject: Re: Ford 3600 won't shift into 4th/8th gear |
The fork is definitely engaged on the rail. Cannot move the left rail rearward with a prybar (BIG screwdriver - didn"t get rough with it). |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
