Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
201g engine
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
cdv
PostPosted: Tue Dec 18, 2012 8:23 pm    Post subject: 201g engine Reply to specific post Reply with quote
in what case model tractors did they use the g201 engine in thanks
Don Rudolph
PostPosted: Tue Dec 18, 2012 9:19 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
201 gas were used in 660 combines, no tractors that I know of.
TimBinWV
PostPosted: Wed Dec 19, 2012 3:05 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
They can, however, be installed in tractors (with some mods)
Joe Young
PostPosted: Wed Dec 19, 2012 4:00 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
I think Don is correct. No ag tractors used the 201, and I don't think the construction tractors used it either.
The 201 is the same engine as the 188g with a bigger bore, so it will bolt up to any 630 with minimal or no modification. The block on a 188/201 is about 1 1/2 inched longer than a 148 (430) or 159 (530) engine, so replacing either of those engines with a 201 would require lengthening the tin, changing out side rails (if equipped) and modifying the throttle linkage.
JGarner
PostPosted: Wed Dec 19, 2012 6:33 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
What mods? I thought the 201G used a 188G block? meL and John Saeli indicate that rebuild parts for 201G are next impossible to get. Just from a little looking, it seems 188G rebuild parts are harder to get than the 188D parts.
Jim
1031D
PostPosted: Wed Dec 19, 2012 7:00 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
Ag kits sells a complete rebuild kit for a G188D for about $625
JGarner
PostPosted: Wed Dec 19, 2012 7:56 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
Can I get 188G rebuild parts? My first contactfor them will be John Saeli when the time comes BUT I am not seeing them on other sources pages.
Jim
TimBinWV
PostPosted: Wed Dec 19, 2012 2:36 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
If the information I've recieved from a couple of guys here is correct, the combine engines had a belt-driven governor, and they won't function properly in an ag application. The engine would have to have the timing chain cover and ag governor controls put on to it. I've got a 440H with a G188D in it,(out of a combine, apparently) and it's got the belt-driven governor on it. I was told by a couple of guys here that I'd have to change the governors out for it to run right. I have a g148 that's got the pieces, but have yet to do it. There may be other things, as well. There's been several discussions on it here.
TimBinWV
PostPosted: Wed Dec 19, 2012 2:39 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
Here's one discussion about putting a 201 into a 411B
201 in a 411B
casecollectorsc
PostPosted: Wed Dec 19, 2012 3:39 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
660s also had 188 gas engines, we have 4 of them. All have internal governors, not belt drive.
PaulD
PostPosted: Thu Dec 20, 2012 7:42 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
There were no case tractors with the 201 engine. The swap to a 201 is fairly easy, finding good used engine parts is kind of easy to do if you take the time and study up. My brother is ToddD in the 201 in a 411b link. We currently have his tractor apart in my garage adding some more power. If you need any more info on the motor or the swap my email is open.
cdv
PostPosted: Thu Dec 20, 2012 8:49 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
PaulD cant find your email cdv10@comcast.net thanks
WY JERRY
PostPosted: Fri Dec 21, 2012 7:22 am    Post subject: Re: 201g engine Reply to specific post Reply with quote
A Continental 201 c.i. gas was used in a Massey Harris model 33. From what I've heard very difficult to find parts.
Scott430
PostPosted: Sun Feb 17, 2013 3:21 pm    Post subject: Re: 201g engine Reply to specific post Reply with quote
I took a 201 out of a 660 combine and bolted it right into my 430 utility and just have to lengthen the top cover oer the engine. no big deal, bolted right up no mods to engine needed.
