Rim painting
Goto page 1, 2  Next
pistol
PostPosted: Wed Dec 19, 2012 6:08 am    Post subject: Rim painting Reply to specific post Reply with quote
what color should I paint Farmall B rims. Yesterdays tractor has Aluminum and McCormik Gray available. I am new at restoration and was looking for tips
glennster
PostPosted: Wed Dec 19, 2012 6:17 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
the rims were originally galvanized. lot of guys will use rustoleum aluminum paint, gm ralleye wheel paint, or just about any silver that looks galvanized.
MisterT
PostPosted: Wed Dec 19, 2012 7:52 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
pistol wrote:
(quoted from post at 15:08:45 12/19/12) what color should I paint Farmall B rims. Yesterdays tractor has Aluminum and McCormik Gray available. I am new at restoration and was looking for tips
If that tractor has ever been repainted ay an IH dealer, the rims would have been painted with aluminum paint, and probably done with a brush. I use Tisco brand paint on mine. They have what is called silver/rim paint. Basically it is aluminum paint, but is a little bit brighter than Rustoleum aluminum.
El Toro
PostPosted: Wed Dec 19, 2012 6:27 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
I painted the rims on this A with yellow lacquer
in 1975. I used on the plow too. Hal
gab
PostPosted: Wed Dec 19, 2012 7:04 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
I painted mine with farm and fleet aluminum, looked to much like a barn roof. did it again with IH silver argent. looks good now
showcrop
PostPosted: Thu Dec 20, 2012 6:20 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
It appears to me that most rims were painted silver like the ones that I have bought new. I have never seen a rim with remnants of galvanizing on them. I'm not saying that they weren't, but I've never seen them. I don't care for the aluminum that rubs off on your fingers, so I use a silver or argent, which looks just like the paint on a new rim.
MisterT
PostPosted: Thu Dec 20, 2012 7:49 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 15:20:59 12/20/12)
I've redone the rims on 3 different Farmalls, ranging in age from 1940 to 1950. On all 3 tractors I used a cup brush on an angle grinder to remove all traces of old paint, right down to bare metal, and I never found even one small indication that those rims had ever been galvanized. Not on the outside, or on the inside. I can only assume those rims were painted aluminum from the factory.
Meangreen
PostPosted: Thu Dec 20, 2012 8:44 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
I just painted a set of rear rims on an Allis WD45 and I went to Case and bought their aluminum paint. You can use hardner in it and thin it for spaying. It was around $45 a quart though...
BANDITFARMER
PostPosted: Thu Dec 20, 2012 12:25 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
When I did my D17 rims I wire wheeled them then sanded them down. I sprayed the inside with Rustoliume cold galvinsing compound (2 good coats). The outside was primed heavy and painted with a brush (2coats) with aluminum paint and let it set for a day when a good coat with a spray can to hide the brush marks and to give it a good shine. It was alot of work put they turned out good. Bandit
Pete76NY
PostPosted: Sun Dec 23, 2012 11:42 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
Closest thing I have found to original is a Toyota Silver...I can get you the number if you need it.
CHUCK CAMBIS
PostPosted: Mon Dec 24, 2012 7:55 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
LOOKS AWESOME!!! I have six sets of wheels that need that treatment/beautification. what day next week can I drop them off!?! chuck.
showcrop
PostPosted: Mon Dec 24, 2012 9:26 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
Pete76NY wrote:
(quoted from post at 00:42:15 12/24/12) Closest thing I have found to original is a Toyota Silver...I can get you the number if you need it.
Pete, I think that your picture of painted silver looks much closer to the new Unverferth than the one painted aluminum.
Sammy in Kansas
PostPosted: Mon Dec 24, 2012 4:24 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
Sure would like to have that toyota number if you would not mind shareing. Thank you.
Joe Dowling
PostPosted: Mon Dec 24, 2012 4:49 pm    Post subject: Re: Rim painting Reply to specific post Reply with quote
I'd like to know what paint would be best put on the rims of my 1952 H..
Inside and out.
Pete76NY
PostPosted: Tue Dec 25, 2012 12:43 am    Post subject: Re: Rim painting Reply to specific post Reply with quote
I'll grab it today when I get out to the shop and post it later tonight.
Goto page 1, 2  Next
Page 1 of 2
