Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Radiator Cap
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
DennislB
PostPosted: Wed Dec 19, 2012 12:23 pm    Post subject: Radiator Cap Reply to specific post Reply with quote
Bought a 39 "B" that was missing a radiator cap. Bought one at Car quest. Too small. Took the cap off of my 42 "B" and it is too small to! Did the early B"s use a different cap?
mdtractormechanic
PostPosted: Wed Dec 19, 2012 12:33 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
The early B radiators were atomspheric (non-pressurized) systems. It uses the same cap as does the gas tank.
Bobby 9891
PostPosted: Wed Dec 19, 2012 12:36 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
What year did they go to pressurized systems ?
old
PostPosted: Wed Dec 19, 2012 3:52 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
I can not tell you what year they pressurized them but can say there is a good chance they never did since the WC, WD and at least some WD45 did not have that system on them
bg/mo
PostPosted: Wed Dec 19, 2012 7:30 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
was shortly after that ,a farmall a or a b cap should fit. as far as pressurized all wd"s and 45"s are.
old
PostPosted: Wed Dec 19, 2012 7:45 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
Guess my WD45 has the wrong radiator on it then since it has the non pressurized one. And my W Speed Patrol is also the non pressurized one
chalmersbob(Pa)
I know that my 47 B and 48 C are presurized. Also my 50 WD and 51 CA are presurized. So I'm going to say after the war they wer mostly predurized. Bob
chalmersbob(Pa)
PostPosted: Wed Dec 19, 2012 7:51 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
According to my parts book, prior to serial # B61222 they were atmospheric type and after same serial # they were pressure type. 61222 would be 1942. Bob
bg/mo
PostPosted: Thu Dec 20, 2012 5:36 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
your saying neither one has a waterpump?
old
PostPosted: Thu Dec 20, 2012 8:50 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
Bot have water pumps but just because it is or is not pressurized has nothing to do with a water pump. You can have a water pump on either type of radiator and it works the same. So why do you believe a system has to be pressurized because it has a water pump???? Lot of old tractors have water pump but the cooling system is non-pressurized
bg/mo
PostPosted: Thu Dec 20, 2012 9:12 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
because on farmall"s non pressurized means no water pump, thats why it is called thermo syphon.I have never seen a wd with out a pressure system, you must have a very very early one, unless someone has done some parst swaping.
bg/mo
PostPosted: Thu Dec 20, 2012 9:47 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
and correction the allis B with non pressure system do have water pumps, got confused there for a bit.
old
PostPosted: Thu Dec 20, 2012 9:48 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
Ya one never knows what may or may not have been done to one of these old tractors. But as I said water pump and pressurized do not fall hand in hand some do some do not but yes my BA Farmall has no water pump and my B JD has no water pump
mdtractormechanic
PostPosted: Thu Dec 20, 2012 10:03 am    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
Dennis,
Just use the gas tank cap and you'll be fine. Steiner's Tractor Parts for one has the cap for about 20 bucks. Just look on-line.
Joe
MisterT
PostPosted: Thu Dec 20, 2012 12:09 pm    Post subject: Re: Radiator Cap Reply to specific post Reply with quote
bg/mo wrote:
(quoted from post at 18:12:30 12/20/12) because on farmall"s non pressurized means no water pump, thats why it is called thermo syphon.I have never seen a wd with out a pressure system, you must have a very very early one, unless someone has done some parst swaping.
That is true ONLY for the Farmall As and Bs. the early Hs had non-pressurized radiators, but also had water pumps.
Goto page 1, 2  Next
Page 1 of 2
