| Author |
Message |
francis Regular
Posted: Wed Dec 19, 2012 3:31 pm Post subject: 4010 not starting up |
i got a 4010 i just rerplaced the crank in,now it wont start,iv got crank and cam timed with its marks,tdc line in center of window,oil pump lined up right,front piston at top dead center,and then valves closed,pretty much timed,but tractor wont start,there was a newly rebuilt injector pump just redone by a man with 40 years expierence,but it wont start up,it smokes blue meanuing timing could be off,but i cant see nothing off unless the wrong piston is at tdc,anyone know where i went wrong?tractor was running perfect till i tried this fresh pump,and no air in system either,but will fire off with ether
also where is the best place to start off at timing?id the numbers above tdc the top numbers and the numbers below btdc? |
| Back to top |
cole in mo. Long Time User
Posted: Wed Dec 19, 2012 4:21 pm Post subject: Re: 4010 not starting up |
If it will start on either, the timeing has got ot be real close, something is wrong with that pump. Take it to a certified diesel shop. |
| Back to top |
david hamblin New User
Posted: Wed Dec 19, 2012 4:34 pm Post subject: Re: 4010 not starting up |
your pump could be 180 degrees off it happens sometimes thanks dave |
| Back to top |
Cliff Nelson Long Time User
Posted: Wed Dec 19, 2012 7:34 pm Post subject: Re: 4010 not starting up |
Is this the original injection pump without speed advance? Without looking at the book I think the 4010 was timed at 14 degrees before tdc which would be the numbers above the tdc mark. Replacement pump with speed advance is timed different but not tdc either. I'll look at the book when I get to the shop in the morning. Could it be 180 degrees off? Maybe was on #6 when the oil pump was installed and timed? |
| Back to top |
Posted: Thu Dec 20, 2012 8:38 am Post subject: Re: 4010 not starting up |
I looked in the book this morning. 4010 without speed advance is timed at 14 degrees before tdc. With speed advance timed at 8 degrees before tdc. |
| Back to top |
francis Regular
Posted: Thu Dec 20, 2012 1:21 pm Post subject: Re: 4010 not starting up |
was on number 1 tdc when set |
| Back to top |
francis Regular
Posted: Thu Dec 20, 2012 1:27 pm Post subject: Re: 4010 not starting up |
clif, i think you answered my question,i been setting the timing at tdc,,then going to 6 ,but in wrong direction,see i was going for the 6 at the top of tdc,,could that be my problem? |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5945 Location: Somerset Ohio
Posted: Thu Dec 20, 2012 2:46 pm Post subject: Re: 4010 not starting up |
When I'm putting one back together I always leave the cam timing marks exposed and lined up then time the oil pump, then set the injector pump in and make sure it's timed while I can still see the cam marks timed too, this assures that "all" time is correct,,no chance of being 180% out on the pump. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
