| Author |
Message |
Inno Tractor Expert
Joined: 11 Nov 2009 Posts: 1875 Location: NW Ontario Canada, Near Beautiful Rainy Lake
Posted: Thu Dec 20, 2012 8:36 am Post subject: Placement of stay bars/stabilizer straps |
Can someone tell me the correct way to attach stabilizer straps/bars for a 3pt back blade on a TO-35 or similar. Pics would be great.
Thanks |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Thu Dec 20, 2012 9:23 am Post subject: Re: Placement of stay bars/stabilizer straps |
Oh Inno, I don't think there is a 'right' way, just whatever works. I give up on 60 year old factory dimensions. The hangers are all different, the pins vary, the bars are always all bent or warped, and one time I straightened one and had to rebend it to get it to on the pin. Just center (centre) your blade and keep moving the pieces of the puzzle until they ...sorta... fit... I ended up with 2 bars that are turnbuckles like a top link... I suppose so you could just adjust it to work without killing half the day laying in snow... good luck. |
| Back to top |
johnpop1 Guest
Posted: Thu Dec 20, 2012 9:37 am Post subject: Re: Placement of stay bars/stabilizer straps |
The antisway bars mount to a bracket underneath the
axle where the fender is mounted. The other end
mounts to the same pin that the lift arms fasten to,
at least this is what I remember on a TO30. The 35
may have a secondary pin on the lift arm forward of
the ball joint, at least this is what the high
wheeled MF65 has. |
| Back to top |
s19438 Long Time User
Posted: Thu Dec 20, 2012 10:05 am Post subject: Re: Placement of stay bars/stabilizer straps |
hope this helps
hope the pics load
mounted on TO-35
| Back to top |
Posted: Thu Dec 20, 2012 10:08 am Post subject: Re: Placement of stay bars/stabilizer straps |
one more pic
| Back to top |
Inno Tractor Expert
Posted: Thu Dec 20, 2012 10:34 am Post subject: Re: Placement of stay bars/stabilizer straps |
Perfect! Thanks.
Not worried about exact dimensions, just want something that will work. Maybe jumping the gun a bit 'cause the 35 isn't all back together yet but I'm hoping over the weekend it might be. |
| Back to top |
Posted: Thu Dec 20, 2012 1:52 pm Post subject: Re: Placement of stay bars/stabilizer straps |
See the way 1943's brackets/hangers are 'pin forward? This is what I would have milk runs with before you tighten bolts, his been there awhile, and all the rest of his pins look like they went in fine, so just perfect.... but none of my stuff is all new and painted... we'll see if santa can improve that... |
| Back to top |
Posted: Thu Dec 20, 2012 6:47 pm Post subject: Re: Placement of stay bars/stabilizer straps |
those pin brackets are OEM. now if you have to go and buy the newer universal pin brackets is where you run into problems and you have to trial and error it before tighening the brackets down. the bars are all basically cut the same has been my experience. |
| Back to top |
Inno Tractor Expert
Posted: Thu Dec 20, 2012 8:42 pm Post subject: Re: Placement of stay bars/stabilizer straps |
Not sure if I even have those pins. It had a loader on it when I got it so a slightly different bracket. |
| Back to top |
supergrumpy Long Time User
Posted: Fri Dec 21, 2012 6:55 pm Post subject: Re: Placement of stay bars/stabilizer straps |
TSC has those adjustable stabilizers, make them any lenth you want, look line a long thin upper link
they sell a kit that gives you the pin under the axle, locktite the nuts |
| Back to top |
John(UK) Long Time User
Posted: Sat Dec 22, 2012 3:22 am Post subject: Re: Placement of stay bars/stabilizer straps |
The brackets under the axle should be slack on the long bolts so they can move slightly. Fit the Pin on the bracket so that it is directly opposite the lower link Pivot Pin. Because of the Multitude of brackets available for different tractors, you need to have the correct ones or they will not allow the bars to pivot without bending. Attach the bars to the bracket pins and the implement end and lift the implement clear of the ground so that the lower links are horizontal. Now push the implement across the width of the tractor a few times just to allow everything to line-up. Now making sure that the Top Link is in-line with the tractor so the implement is central to the tractor. Now tighten the Fender Bolts and providing that you have the correct brackets, the implement will lift and lower without bending the stabilizer bars, if they do bend then suspect that the brackets are wrong. The Stabilizer Bars should be the same length as the Lower Link arms of the 3 point, Centre to Centre of the pin holes. If you have adjustable bars, set them the same length as the lower link arms on the 3 point, just because you can adjust them to fit without trying to adjust the brackets under the axle will not allow them to move in the same arc as the lower link arms and something will bend or break. Any problems you may have with Stabilizers is almost always due to incorrect setting of the Brackets and pins under the axle and you tend to shy away from adjusting the brackets because the bolts are rusted and difficult to slacken off the nuts, but there is no easy way if you want it correct..John(UK)..fergusontractors@hotmail.com |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
