Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
still having electrical problems
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
wisconsin johnnie
PostPosted: Thu Dec 20, 2012 12:15 pm    Post subject: still having electrical problems Reply to specific post Reply with quote
on my 8n, the original problem was a dead battery. I charged up the battery and installed it. I tried to start it up and heared a buzzing sound coming from the starter area. I leaned over, put my hand on selinoid and could feel it vibrating. So i replaced my selinoid. ( 3 point selinoid ) went to hook up the battery and when I touched the neg cable to the post, (having the pos alreaady hooked up) it sparked, and the moter turned over. I then disconnected the middle cable on selinoid and tried to hook up the battery. The thought was if there was a short in the starter button I could diagnois it as either a short in the wire or the starter button was stuck open. Again a spark. I then replaced all of my wiring except the lights, I just disconnected them. With new wires , hooking up the battery produced another spark. Any ideas? Could my voltage regular be the problem?
Bruce(VA)
PostPosted: Thu Dec 20, 2012 12:24 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
" Could my voltage regular be the problem? "
No. It's not in the starting circuit.
Is it 6v or 12v?
Does it have the OEM starter switch on the tranny & the OEM key switch on the dash?
Is the solenoid installed w/ the small terminal toward the block?
75 Tips
Dean
PostPosted: Thu Dec 20, 2012 12:32 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
Almost certainly not the solenoid but could be the battery. Have you load tested the battery?
What size (gage) are the battery cables?
Are all of the connections clean and tight?
Dean
JMOR
PostPosted: Thu Dec 20, 2012 12:39 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
wisconsin johnnie wrote:
(quoted from post at 16:15:08 12/20/12) on my 8n, the original problem was a dead battery. I charged up the battery and installed it. I tried to start it up and heared a buzzing sound coming from the starter area. I leaned over, put my hand on selinoid and could feel it vibrating. So i replaced my selinoid. ( 3 point selinoid ) went to hook up the battery and when I touched the neg cable to the post, (having the pos alreaady hooked up) it sparked, and the moter turned over. I then disconnected the middle cable on selinoid and tried to hook up the battery. The thought was if there was a short in the starter button I could diagnois it as either a short in the wire or the starter button was stuck open. Again a spark. I then replaced all of my wiring except the lights, I just disconnected them. With new wires , hooking up the battery produced another spark. Any ideas? Could my voltage regular be the problem?
In addition to the small third terminal, you should have another relatively small wire connected to the large solenoid terminal that also has battery cable on it. Remove that small wire & set it aside such that now the only connection to the solenoid is cable from battery and the other large terminal connection to starter motor. Empty small 3rd terminal. Now see if your connection still makes a spark?????????
wisconsin johnnie
PostPosted: Thu Dec 20, 2012 12:54 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
To answer some of the questions posed to me so far. Got a new battery. Termals connection & the ground were cleaned up. I have a regular battery cable for the pos and a metal webing looking terminal for the ground. The middle post of the selinoid is outward looking. i have the battery cable connection of the selinoid at 9 oclock, the starter terminal at 6 oclock and the other one at 3oclock.
My starter button is located close to the gear shifter boot and my key switch is on the left hand side. Both pieces are original as far as i know.
wisconsin johnnie
PostPosted: Thu Dec 20, 2012 12:55 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
it's a 12 volt converted about 10 years ago
old
PostPosted: Thu Dec 20, 2012 1:00 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
The 3 post solenoids have a battery side and a starter side and if you mix them up it can/will do just as it is doing to you. Switch it around
JMOR
PostPosted: Thu Dec 20, 2012 1:02 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
So, much for the clock, but........what happened with ONLY the batt cable to one large terminal & starter motor to other large terminal and neither of the other wires connected (nothing other than battery cable & starter motor).. Spark or not??
wisconsin johnnie
PostPosted: Thu Dec 20, 2012 2:27 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
i dont have a small wire that goes along with the battery cablewire
I have 3 terminals all have only 1 wire going to it. Where does that smaller wire come from?
JMOR
PostPosted: Thu Dec 20, 2012 2:35 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
(quoted from post at 18:27:29 12/20/12)
All electrical 'stuff' besides the starter have to get power from some place and that is generally (certainly in factory form) by way of a wire from the battery terminal of the solenoid, going to the ammeter & from ammeter to terminal block, where all else ties in, including key switch & ignition.
DON TX
PostPosted: Thu Dec 20, 2012 4:25 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
"The middle post of the selinoid is outward looking."
The middle post should be inward looking.
HTH
DON TX
BillM (OH)
PostPosted: Thu Dec 20, 2012 5:35 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
As JMOR points out, there should be 3 wires connected to the solenoid:
1. Large cable from battery on battery side terminal
2. Wire from ammeter on battery side terminal
3. Wire from starter switch to the small terminal FACING THE BLOCK on the solenoid.
Sounds like your solenoid is on backwards, as you say the small terminal is facing away from the block,
Royse
PostPosted: Thu Dec 20, 2012 5:49 pm    Post subject: Re: still having electrical problems Reply to specific post Reply with quote
Maybe you could post a picture of what you've got to help us out.
It does sound like your solenoid is mounted backwards, but unless you have
other wires ran incorrectly or a stuck solenoid, that would make it not work at all.
