Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Hydraulic Toplink
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Fuddy Duddy
PostPosted: Thu Dec 20, 2012 6:57 pm    Post subject: Hydraulic Toplink Reply to specific post Reply with quote
Anyone ever use a hydraulic top link? I been using a dirt scoop that works great. Puts the weight on the rear tires where you need it when moving dirt. Problem was, Once full I would raise the 3 point and half to dirt would fall out. Seems if I had a hydraulic top link then I could roll the bucket back to help keep the dirt in it. I've got a FEL on the tractor. When I replaced the control spool I installed one with 3 levers. The FEL only uses one and a haft of them. So I've got a spare (and a half) for such needs. Make since? Also thought while working on the drive way, Wouldn't be a good idea to have the leveling link hydraulic too? As I was trying to make the center higher to help roll the rain water off. I kelp having to adjust its angle.
I believe these are good ideas. Just wondering if anyone else is doing this?. And if there would be any down side?
Keep thinking about such things and maybe I have my six foot blade working as as six way blade before I'm finished.
Paul in Edmonton
PostPosted: Thu Dec 20, 2012 7:12 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Doesn't sound like a bad idea to me--I don't have any implements that would need it, but that dirt scoop sounds like it could use it.
I wish my back blade was remotely controllable (in rotation, of course; up and down works fine with the position control). But since I don't have hydraulics at all, it would be a lot of work. And besides, I want about 300° of rotation in the blade, so there's no way a ram would work--it would need a motor and gears. But it would sure be nice to not have to jump on/off about fifteen times in the course of clearing snow from my drive to put the blade where I want it. Last weekend, when I was getting off to adjust the blade, I accidentally kicked it into gear, and the tractor started driving away without me! Shocked
-Paul
Bob Harvey
PostPosted: Thu Dec 20, 2012 7:21 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Probly a good thing that you are as fleet as a Gazelle ! MXms&HNY
Ultradog MN
PostPosted: Thu Dec 20, 2012 7:24 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
If you put a hydraulic top link on your tractor you will Never go back to a screw type.
Plow, back blade, rear scoop and especially a boom pole will all be handier with one.
I made my own. Bought a hyd cylinder on craigslist and welded the swivels from a screw type on it.
Fuddy Duddy
PostPosted: Thu Dec 20, 2012 8:05 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
I thought it would be a good idea. Just hadn't heard anyone talk about it. As far as the Back Blade, You could have a Lynch pin to release it when you needed to turn it around backwards. Got to jump off some time. Just not near as much. Anyone wanting to do it with out a FEL you can install a Hydraulic pump with out the loader. As for me, I think I'm going to go for it.
Paul in Edmonton
PostPosted: Thu Dec 20, 2012 8:19 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
True. But I find it's the switching from backwards to forwards is what I'm most often jumping off for.
-Paul
Dean
PostPosted: Thu Dec 20, 2012 8:45 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
I use a hydraulic top link when using a slip scoop or box blade. It's the cat's meow for these implements and you will wonder how you got along without one once you have one.
One must be careful though with a box blade with rippers as one can puncture tires with the rippers if not paying attention.
If you buy one, be certain to get one with pilot operated check valves if you wish it to remain in position during use.
Dean
Dean
old
PostPosted: Thu Dec 20, 2012 9:31 pm    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Best you stay home because if you ever come to see me your going to be back here so much that you will have to get a key to my place LOL. I have so much junk laying around and so many things I have built and played with and your question is just another thing that I have BTDT and figured out to many crazy thing to do with
Hobo,NC
PostPosted: Fri Dec 21, 2012 4:44 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Dawg are Dean,, how difficult is it to hook up to implements.... It seems to me it would be to align the top link...
Ultradog MN
PostPosted: Fri Dec 21, 2012 5:09 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Hobo,
No different than a screw type. Maybe quicker as you can slide the cylinder in or out to the right length to attach the pin.
You thinking about making one?
I know you too much of a cheap arse to buy one and that's a compliment by the way.
Expensive
Hobo,NC
PostPosted: Fri Dec 21, 2012 5:23 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
I did not know you could slide if Embarassed ,,, Theirs a possibility I may have to have one for my 3000,,, I took the loader off have the controls and a couple hundred to burn.... I will get you a few pix will need info on how to hook it up Wink
Fuddy Duddy
PostPosted: Fri Dec 21, 2012 6:19 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
"pilot operated check valves" That's a new one on me. Is that built into the cylinder or added in the line? Did a short Google search. and just got confused. I'll research some more once I have the time to do so. I of course understand how a check valve works on a well. But in Hydraulics the flow has to go both ways.
I guess the pilot operated check valve will add to the cost of a cylinder. Double the cost or what?
chevytaHOE5674
PostPosted: Fri Dec 21, 2012 6:30 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Pilot operated check valves are directly on the cylinder and the hose attaches to them. They are designed to reduce creep or drift in a cylinder they will also hold the cylinders position if the hoses were to burst. This assumes there is no bypass in the pistol seals of the cylinder.
Dean
PostPosted: Fri Dec 21, 2012 7:30 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
Hook up is not a big issue as I use mine mostly on my 860 with the slip scoop, box blade or boom.
I can reach the lift and remote controls when installing the top link pins and can usually muscle things around a bit if necessary.
Dean
Dean
PostPosted: Fri Dec 21, 2012 7:34 am    Post subject: Re: Hydraulic Toplink Reply to specific post Reply with quote
The check valves are mounted externally on the cylinder as part of the unit.
I bought mine two or three years ago. IIRC, I paid a about $275 for the top link assembly and an optional hose/connection kit.
Dean
Goto page 1, 2  Next
Page 1 of 2
