| Author |
Message |
Animal Tractor Expert
Posted: Fri Dec 21, 2012 2:11 pm Post subject: Electrical ? |
I don't know an ohm from my elbow so I would appreciate it if you can straighten me out on this. On the new cars the battery cables are very small and they are 12 volt systems with electronic ignition and power this and that. How come on an old tractor that you convert to 12 volts that you still need cable the bigger the better when you use just a starter and coil, and most the time the starter is a 6 volt starter. What is putting such a load on it that you can not use the smaller modern cable? Thanks in advance! |
| Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 11271 Location: Old Church VA
Posted: Fri Dec 21, 2012 2:15 pm Post subject: Re: Electrical ? |
" How come on an old tractor that you convert to 12 volts that you still need cable the bigger the better "
You don't. The smaller cables used on 12v cars work just fine on 12v tractors.
75 Tips
| Back to top |
Royse Tractor Expert
Posted: Fri Dec 21, 2012 2:51 pm Post subject: Re: Electrical ? |
Newer cars, newer technology?
I've never actually measured the current draw on the starters, but it's
possible the newer starters, specially gear reduction ones, draw less power.
As Bruce said, I've used the smaller cables on 12 volt conversions.
They work fine.
But if you have the large cables, and they're in good shape,
I wouldn't spend any money to change them.
The larger ones don't heat up as quickly.
The only drawback to them that I can think of is that they are stiff.
| Back to top |
Posted: Fri Dec 21, 2012 2:55 pm Post subject: Re: Electrical ? |
Bruce, don't think that I am doubting you because I am not. I just read on one of these forums a few days ago how much easier a tractor would start using bigger cables and that put me to wondering why. |
| Back to top |
JMOR Tractor Guru
Posted: Fri Dec 21, 2012 3:08 pm Post subject: Re: Electrical ? |
| Animal wrote: | | (quoted from post at 18:55:30 12/21/12) Bruce, don't think that I am doubting you because I am not. I just read on one of these forums a few days ago how much easier a tractor would start using bigger cables and that put me to wondering why. | "Read the other day"....you can get any answer you want on the internet. Just search until you find the answer that suits you.  |
| Back to top |
Jubilee85 Regular
Posted: Fri Dec 21, 2012 3:15 pm Post subject: Re: Electrical ? |
think of you trying to put out a fire, you got a garden hose and you are doing a fair job, then someone gives you a hose that is a little bit larger, like a 1" hose, (old one was standard 1/2")the amount of water is far greater, more flow. The pressure could have changed too.
In electricity, water flow is kinda like amperes, and water pressure is like voltage.
the two combined make the big picture. In electricity this term is Watts ( total power)
If your starter on your tractor needs, 100 watts of power to do its job (number made up) - the old 6 volts X 16+ amps would be the amount of total power, but if you changed to 12 volts, the amp load would have gone down to 8 or so. The larger cable you are thinking about are needed due to the larger amp flow ( think water flow) for the 6 volt. New cars have the same ol batteries but the starters are probally easier to turn over the engines might be easier to turn over so the amps could be less.
the ol adage "bigger is better is true in elecrical terms......HTH |
| Back to top |
kylemorley Regular
Posted: Fri Dec 21, 2012 4:03 pm Post subject: Re: Electrical ? |
With the caution that auto manufacturers don't like to waste money on unnecessary copper so the the OEM cables on 12v installations are often the smallest that will do the job, most of the time. So if you are replacing cables on an 9-2-8n converted to 12V you don't have to use big 6v cables, but something larger than the minimum size Fred's Home and Auto is selling might not a bad idea.
I used to do oversized battery cable installations for Piper aircraft. These had the battery in the back seat, and used aluminum cables. Going a size or two larger, and using copper instead of aluminum, would totally transform cold weather starting with no other changes. |
| Back to top |
Plane Bart Long Time User
Posted: Fri Dec 21, 2012 5:48 pm Post subject: Re: Electrical ? |
The lager cable carries the current flow (amps) better
Rule of thumb in electrical work the higher the voltage the lower the amperage. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50476 Location: Lake of the Ozarks area of MO
Posted: Fri Dec 21, 2012 6:00 pm Post subject: Re: Electrical ? |
Big cables are for 6 volt system where the amp draw is twice as high as 12 volts. I use the auto type battery cables on my tractor that have been switch to 12 volts and never had any problems |
| Back to top |
Posted: Fri Dec 21, 2012 6:13 pm Post subject: Re: Electrical ? |
| Plane Bart wrote: | (quoted from post at 21:48:09 12/21/12) The lager cable carries the current flow (amps) better
Ummm, guys?
Ohm's law says Current (amps)(I) is equal to the voltage (E)
divided by the resistance (R) of the circuit. I = E/R
So for the same circuit resistance, more voltage would mean more current.
Strictly speaking direct current here.
Did I miss something? |
| Back to top |
souNdguy Tractor Guru
Posted: Fri Dec 21, 2012 6:40 pm Post subject: Re: Electrical ? |
how much power does that starter take.
P=EI
use the power as a constant and re do the calcs see what happens 'wink' |
| Back to top |
Posted: Fri Dec 21, 2012 8:19 pm Post subject: Re: Electrical ? |
| soundguy wrote: | | (quoted from post at 22:40:34 12/21/12)use the power as a constant and re do the calcs see what happens 'wink' |
Power required by the starter as a constant.
Hmmm. That's an interesting thought.
I see the math.
Let me think on that one a while. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
