Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
PTO shaft Length
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
hayshaker5
PostPosted: Sat Dec 22, 2012 6:40 am    Post subject: PTO shaft Length Reply to specific post Reply with quote
I recently purchased a 990 mower conditioner at an auction minus the correct front half of the PTO drive shaft. Somebody put a very obvious wrong shaft with it instead of correct one. I have another shaft here but is too long. I would like to find out what the correct measurements for the actual shaft and shield. I would even consider buying one if anyone has one to sell.
Thank you.
tomstractorsandtoys1
PostPosted: Sat Dec 22, 2012 5:45 pm    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
Sorry but I do not know the length,but most implements like that used about the same shaft,at least Deere did.I have a large pile of shafts and most equipment uses the same one.The IH 990 was a very good machine,we had two seven ft. machines and mowed lots of hay with them.We changed to NH because we thought that in alfalfa the rolls in the NH made hay dry faster,but in grass the 990 was a great machine.There is a Fry's machinery in Muncy PA that has a huge implement parts yard and I am sure they would have the correct shaft.Sorry but I can not find the phone number.
showcrop
PostPosted: Sat Dec 22, 2012 6:44 pm    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
hayshaker5 wrote:
(quoted from post at 07:40:11 12/22/12) I recently purchased a 990 mower conditioner at an auction minus the correct front half of the PTO drive shaft. Somebody put a very obvious wrong shaft with it instead of correct one. I have another shaft here but is too long. I would like to find out what the correct measurements for the actual shaft and shield. I would even consider buying one if anyone has one to sell.
Thank you.
I have one, it even still has the shield. Where are you located?
hayshaker5
PostPosted: Sat Dec 22, 2012 8:31 pm    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
I'm in Eastern Iowa
hayshaker5
PostPosted: Sat Dec 22, 2012 8:40 pm    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
I have numerous pto shafts, only one will fit but it is too long, I think I can cut it to fit but have not found another 990 available to get the measurements.
Tx Jim
PostPosted: Sun Dec 23, 2012 4:04 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
hayshaker5 wrote:
(quoted from post at 00:40:53 12/23/12) I have numerous pto shafts, only one will fit but it is too long, I think I can cut it to fit but have not found another 990 available to get the measurements.
Fairly simple to ascertain the correct length. Just hook your 990 to your tractor,turn tractor 90 degrees to cutter with NEW(used) shaft installed on tractor then set the 2 pto shafts(one installed on tractor pto & 990 shaft) side by side and cut to correct length. At the 90 degree turn the shafts will never slide any closer together than they are right then.
BushogPapa
PostPosted: Sun Dec 23, 2012 9:51 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
Unless the tractor's front is heading up-hill..
Give it a little more slack..
Ron..
Tx Jim
PostPosted: Sun Dec 23, 2012 10:03 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
BushogPapa wrote:
(quoted from post at 13:51:18 12/23/12)
Ron..
Ron
The hill you refer to would have to be a lot higher than I would want to drive a tractor up Wink
BushogPapa
PostPosted: Sun Dec 23, 2012 10:21 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
Ha..yea.. but ya never know about crossing uneven ground...!
Today's larger equipment won't give much..just breaks something..!
Ron..
Don-Wi
PostPosted: Sun Dec 23, 2012 2:00 pm    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
I was always under the impression that the 2 halves should be the same length, so I would suspect if you made the front the same length as the back 1/2, you'd be set.
Donovan from Wisconsin
Tx Jim
PostPosted: Mon Dec 24, 2012 3:44 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
Don-Wi wrote:
(quoted from post at 18:00:16 12/23/12) I was always under the impression that the 2 halves should be the same length, so I would suspect if you made the front the same length as the back 1/2, you'd be set.
Doing as I described above the shafts would be close to the same length and would be the same with an Equal Angle hitch.
hayshaker5
PostPosted: Thu Dec 27, 2012 5:41 am    Post subject: Re: PTO shaft Length Reply to specific post Reply with quote
Thanks for all the info. I will try these suggestions.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
