BS 6 hp - Oil Capacity?
Tim in New York
PostPosted: Sat Dec 22, 2012 7:53 pm    Post subject: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
I bought my Troy-bilt tiller at an auction, so I have no manual for it. I changed the oil for storage, but I am not sure how much the crankcase holds. The tiller is a Super Bronco, the engine a 6 hp overhead valve. Does anyone know what the capacity is?
Thanks,
Tim
El Toro
PostPosted: Sun Dec 23, 2012 4:29 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
If it doesn't have a dipstick and you have to pour the oil directly into the oil pan, the oil level should be near the top of the filler hole.
Hal
El Toro
PostPosted: Sun Dec 23, 2012 4:35 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
Hal
DiyDave
PostPosted: Sun Dec 23, 2012 6:56 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
About 20-22 oz, there was a start up can of oil, that came with our troybuilt.
G1355
PostPosted: Sun Dec 23, 2012 10:28 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
Around one quart
Tim in New York
PostPosted: Sun Dec 23, 2012 2:23 pm    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
Thanks for the replies. 16 oz seemed to come close to filling.
K-Mo
PostPosted: Mon Dec 24, 2012 4:01 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
Go to the B&S website and you should be able to download an owner's manual and parts list.
rustyj14
PostPosted: Thu Jan 03, 2013 11:18 am    Post subject: Re: BS 6 hp - Oil Capacity? Reply to specific post Reply with quote
When you pour the oil into the filler hole, keep adding oil until it runs out. If you stop when the oil first comes to the top of the hole, there might be room for more oil, so check it, until you are sure it is filled correctly. cold weather makes the oil run slower. Works for me!
Note: This doesn't apply, if you have a dip-stick and tube! Believe it or not--i have gotten engines where the owner poured in the oil, to the top of the dip-stick tube! MMMM
