Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
reversing a electric motor
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
schrade
PostPosted: Sun Dec 23, 2012 5:19 am    Post subject: reversing a electric motor Reply to specific post Reply with quote
have a franklin electric 1/2 hp motor can it be reversed how only 110 volt
Uncle Ernie
PostPosted: Sun Dec 23, 2012 5:23 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Look on the motor tag or the inside of the electrical cover. If it can be reversed the connections should be shown there.
John T
PostPosted: Sun Dec 23, 2012 5:32 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
It can be reversed if it has the appropriate accessible start winding terminals, should be avaialable right under the junction box where wires enter the motor and often a diagram and instructions are shown there.
A single phase split phase motor (unlike a 3 phase) isnt self starting, there needs to be an offset usually temporary seperate start winding which gets it spinning in one direction and is then disabled by a centrifugal switch.
Look under the motors entrance box for wires or diagrams or directions......
If I missed anything hopefully the other fine sparky gents here can add to this, Im a tad rusty in my old age lol
Merry CHRISTmas, a celebration of the birth of Christ and also a federal Holiday
John T
Paul Janke
PostPosted: Sun Dec 23, 2012 5:46 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
I reversed an electric motor which didn't have the leads available. To do so, I took it apart and put the rotating parts and the end caps back in from the opposite ends. It's probably more accurate to say that I turned the middle section with all the wiring and windings end for end.
schrade
PostPosted: Sun Dec 23, 2012 5:52 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
This is an older motor cant find any wiring info on it or I wouldn't have asked
John T
PostPosted: Sun Dec 23, 2012 5:53 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Sure thing, that accomplishes what would have been done had it the easier accessbile wiring leads.......
John T
Dusty MI
PostPosted: Sun Dec 23, 2012 5:55 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
It depends on the type of motor and like said it's windings. Most motors if the can be reversed you just change 2 wires, don't remember for sure, I think it's 5 & 7.
Some motors, induction replusion, you shift the brushes.
Dusty
Jim's right it is 5 & 8.
JimKS
PostPosted: Sun Dec 23, 2012 6:21 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
wire #s 5 and 8 are the most common to switch.
Jim
George Marsh
PostPosted: Sun Dec 23, 2012 6:24 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Post a pic of the motor with the cover plate removed, so we can see where you connect the power to. Usually the info you need is on the back side of the cover plate.
When I don't have the info I need, I take the motor apart. Look for the end switch. One of the wires on the end switch will go to the start winding and the other wire will go to a terminal where your 110v is connected, say L1. Use an ohmmeter and determine which wire of the start winding goes to L2. By reversing the connections of the start winding you will reverse the motor's direction. LOL
buickanddeere
PostPosted: Sun Dec 23, 2012 7:50 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Reverse the polarity of the start windings. They are the pair with the higher resistance.
Dick2
PostPosted: Sun Dec 23, 2012 8:52 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Just turn the motor around so the shaft is facing 180 degrees from where it was.
Sorry. Just couldn't resist that. The devil made me do it!
John T
PostPosted: Sun Dec 23, 2012 9:03 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Or just move.......I think they turn the opposite direction if youre in the Northern or Southern hemisphere right???????
John T
old
PostPosted: Sun Dec 23, 2012 10:23 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
On many motors there is a diagram on the back side of the electric cover plate that will tell you how to rewire it is it can be reversed that is
schrade
PostPosted: Sun Dec 30, 2012 7:00 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
Findly got it after afew trys found the right wires
buickanddeere
PostPosted: Sun Dec 30, 2012 7:48 am    Post subject: Re: reversing a electric motor Reply to specific post Reply with quote
You guessed instead of finding out for certain first?
Goto page 1, 2  Next
Page 1 of 2
