Cable End with Threads - What to Call It?
Kerwin
PostPosted: Sun Dec 23, 2012 7:44 am    Post subject: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
I"ve got an Allis Model 78 side delivery rake that uses two steel lift cables, each with a clevis on one end and the other end crimped into a threaded stud. Both cables are frayed and broken, so would like to replace.
What do you call the threaded stud that would have an end open for crimping in a cable? I would imagine they are still available and not unique to the rake, just haven"t hit on the right name for searching.
DH in Carolina
PostPosted: Sun Dec 23, 2012 8:30 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Mcmaster-Carr. Search for cable ends.
MarkB_MI
PostPosted: Sun Dec 23, 2012 10:01 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Swaged cable studs. If you have a marina or boat dealer nearby who works on sailboats, they can probably fix you up. It takes a special tool to swage them.
Dalex
PostPosted: Sun Dec 23, 2012 10:40 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
They are widely used in Aircraft too , maybe check with a mechanic @ your local airport and see where he gets them ...
El Toro
PostPosted: Sun Dec 23, 2012 12:31 pm    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Anyway to run the cable thru a hole then use several cable clamps to secure the loop? Hal
tx68
PostPosted: Sun Dec 23, 2012 6:58 pm    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Nicopress
MarkB_MI
PostPosted: Mon Dec 24, 2012 2:12 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
The fitting he describes is not Nicopress, although it might be possible to replace it using Nicopress and other hardware.
DiyDave
PostPosted: Mon Dec 24, 2012 5:18 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
You can swedge them with a bolt cutter that you modify, by grinding the correct profile, into the blade halves!
Puddles
PostPosted: Mon Dec 24, 2012 6:56 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
You could always run down to the hardware store, buy a eye bolt, and roll a farmers eye in your wire rope. They are real easy to do. Now a loggers splice is just a little harder to do.
http://www.iandisling.com/Did_You_Know/003/DYK_003.htm
Puddles
PostPosted: Mon Dec 24, 2012 7:06 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Another good video.
http://youtu.be/jBlvFRDHdgM
greygoat
PostPosted: Mon Dec 24, 2012 7:11 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
Is that end called a "Spindle" or "Thimble"
Puddles
PostPosted: Mon Dec 24, 2012 7:21 am    Post subject: Re: Cable End with Threads - What to Call It? Reply to specific post Reply with quote
The unit in the middle of the eye in the last picture, we always called them thimbles.
