| Author |
Message |
ESKAY New User
Posted: Mon Dec 24, 2012 9:47 am Post subject: 641 fuel shut off valve |
I"m about to replace a leaking fuel shut off valve on my 641, any advivce, suggestions or things to be aware of ? Thanks ESKAY |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50436 Location: Lake of the Ozarks area of MO
Posted: Mon Dec 24, 2012 9:55 am Post subject: Re: 641 fuel shut off valve |
Be sure to buy a good one not one of the many China junk ones that are sold now days. Be ready to pay a good price for one if you want it to work as it should and last a few years |
| Back to top |
Will Gumbert Regular
Joined: 12 Mar 2012 Posts: 187 Location: Garrett County, MD
Posted: Mon Dec 24, 2012 11:16 am Post subject: Re: 641 fuel shut off valve |
Depending on what's wrong it might be best to repair the valve you have, if it's the screw-type. This has been discussed on this forum in detail, but it involves replacing the o-ring inside (and the one sealing the valve to the tank). Once you have the valve out, you can carefully chisel off the rivet which allows you to remove the stem and o-ring. Replace the o-ring, then replace the rivet with a self-tapping screw of just the right length to prevent the stem from coming out. A little tricky but definately do-able. -Will |
| Back to top |
Tom Bond Regular
Posted: Tue Dec 25, 2012 6:39 pm Post subject: Re: 641 fuel shut off valve |
I'll second the repair option. VERY easy to do. I drilled my rivet out and tapped it for a machine screw instead of using self tapper. Same result though. If it ever starts to leak again, no need to remove valve from tank. Just use a 90° screwdriver, remove the screw, replace the "O"ring and reinstall in reverse order. As mentioned above, the new imports are junk and will have to be replaced almost annually like clockwork. |
| Back to top |
ESKAY New User
Posted: Tue Dec 25, 2012 7:34 pm Post subject: Re: 641 fuel shut off valve |
Thank you to all who repsonded, I will take your advice and repair the old one. Thanks again and Merry Christmas to all |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
