| Author |
Message |
Jim Wieringa Guest
Posted: Mon Dec 24, 2012 10:00 am Post subject: Run with choke on - why? |
I have a 1966 2000 with Holley carb. Why does it need the choke pulled out to run it's best? Push the choke off and the tractor dies. What do I have to look for? Thanks Jim |
| Back to top |
Larry NCKS Tractor Guru
Joined: 23 Dec 2001 Posts: 3711 Location: Washington, KS/Lincoln, NE
Posted: Mon Dec 24, 2012 10:11 am Post subject: Re: Run with choke on - why? |
Either it has a vaccuum leak, or your carb needs cleaned/overauled. The latter is more likely! |
| Back to top |
3000OH Regular
Posted: Mon Dec 24, 2012 12:46 pm Post subject: Re: Run with choke on - why? |
Long-known issue. Search the archives for Holley (or its alt spelling). Some swear by 'em, some at 'em. Count me in the latter. Bit the bullet some years ago and bought a Zenith for our '65, zero problems since then. But others like those H-carbs. So do yourself a favor and go back and read both sides of the story.
Have a good holiday. |
| Back to top |
Jim Wieringa Guest
Posted: Mon Dec 24, 2012 4:01 pm Post subject: Re: Run with choke on - why? |
I had the tractor running nice and smooth with the choke on and took a spray bottle with soap and water in it and sprayed every place I could think of and it made no difference in the running. So I guess I can deduct that it is needing a carb kit eh!! |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9850 Location: Western Montana
Posted: Mon Dec 24, 2012 5:40 pm Post subject: Re: Run with choke on - why? |
What were you hoping to see with soapy water?
Try spraying starting fluid(CAREFULLY!)around the throttle shaft, the carb to intake manifold interface, and the cylinder head to manifold interface. if you heaar the engine speed up, you"ve found your leak. look for vcracks or rust holes in the intake manifold also. |
| Back to top |
JMOR Tractor Guru
Posted: Mon Dec 24, 2012 6:08 pm Post subject: Re: Run with choke on - why? |
| Jerry/MT wrote: | (quoted from post at 21:40:02 12/24/12) What were you hoping to see with soapy water?
Try spraying starting fluid(CAREFULLY!)around the throttle shaft, the carb to intake manifold interface, and the cylinder head to manifold interface. if you heaar the engine speed up, you"ve found your leak. look for vcracks or rust holes in the intake manifold also. | Bubbles inside intake tract?  |
| Back to top |
TimInd New User
Posted: Mon Dec 24, 2012 9:44 pm Post subject: Re: Run with choke on - why? |
Another way to find a vacuum leak is with a bottle of propane, not lit obviously. Let a small amount of propane leak out on go over the obvious places where a leak could occur. When the engine speeds up, that's it. |
| Back to top |
3000OH Regular
Posted: Tue Dec 25, 2012 8:22 am Post subject: Re: Run with choke on - why? |
As for a carb rebuild, some here say that it should only be a genuine CNH kit, not some aftermarket. You may find a seized/corroded accel pump piston.
BTDT before I tossed in the towel on the Holley. Not cheap to do. CNH does not stock replacement Holleys for 2000/3000/4000, only the Zeniths. |
| Back to top |
kgrove78 Guest
Posted: Tue Dec 25, 2012 8:29 am Post subject: Re: Run with choke on - why? |
sounds like it needs rebuild i have done several holley carbs for customers and neighbors i use kits from napa or tsc some have been running for several years since. not overly complacated to do. and i use carb clean to look for vac leaks safer than starting fluid with same results. good luck. |
| Back to top |
DaveH IA Long Time User
Joined: 18 Apr 2004 Posts: 582 Location: Central Iowa
Posted: Tue Dec 25, 2012 8:39 am Post subject: Re: Run with choke on - why? |
Also check for good fuel flow from tank-- and I think there is a filter on the fuel pump, Might not be getting fuel to the carb ?? just something else to check |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
