| Author |
Message |
lenray Long Time User
Posted: Tue Dec 25, 2012 9:57 am Post subject: Case 26 Backhoe on a DO MOR Tractor |
It has foot pedals for the swing. One of the pistons-servos not sure of the name leaks when the lever is moved back and forth to move the boom. Guessing there are O rings on the piston - servo Is this an easy fix??? What am I looking at as far as the fix. The piston -servo travels up and down maybe an inch or a little more. Thanks for any help. |
| Back to top |
curtis larson Regular
Posted: Tue Dec 25, 2012 2:36 pm Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
I think your looking at the spool in the control valve. |
| Back to top |
Posted: Tue Dec 25, 2012 2:47 pm Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
Yeah that is the wording the SPOOL. THANKS
ANY IDEAS ON REPAIRING???????????????? |
| Back to top |
DiyDave Tractor Guru
Posted: Tue Dec 25, 2012 3:42 pm Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
I think there are packings, in the ends of the spools, but if there is serious wear in the spool, replacing the packing won't do much. Finding a match near enough, to match up with the linkages might prove too much a fight. |
| Back to top |
AJ. Long Time User
Posted: Tue Dec 25, 2012 3:57 pm Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
There is an o'ring at the top of and bottom of each spool valve,remove the cap from the reservoir to relieve any pressure,clean around the top end of the valve and the cap on the bottom,remove the clevis pin and disconnect the rod from the valve,remove the two bolts from the bottom cap and remove it,have an oil catch underneath,if its only the top o'ring you need to replace,push down the valve past the o'ring and replace the ring,if you are going to replace the two you will have to remove the spool valve,both o'rings are marked in the parts drawing by a red square.
AJ  |
| Back to top |
Posted: Tue Dec 25, 2012 3:59 pm Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
There is a Quad ring on the top and bottom . A o-ring will work. easy fix. |
| Back to top |
Posted: Wed Dec 26, 2012 7:48 am Post subject: Re: Case 26 Backhoe on a DO MOR Tractor |
Thankyou for the information fellas---Very helpful.
This is an older hoe installed on a 1970s era DO MOR tractor that was made in Manistee, Mi. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
