| Author |
Message |
JayinNY Tractor Guru
Posted: Tue Dec 25, 2012 11:00 am Post subject: Pink salt curing |
Can anyone give me some advice on how to pink salt cure a ham? My brother got a butchered pig, none of the meat is smoked, we already made bacon, cured it than smoked it. Now we wanna try curing and smoking the fresh hams! My brother ordered the salt, so were gonna try it soon! Any tips, thanks, J |
| Back to top |
Rob03 New User
Posted: Tue Dec 25, 2012 11:26 am Post subject: Re: Pink salt curing |
I always use the Morton Quick Cure salt. Use 2 tablespoons salt to 1 lb of meat. So I use the salt, dark brown sugar and pepper. Cover the meat in the salt, sugar and pepper mix. Put in an air tight container and put in the refrigerator for 10 day's. Turn the ham over once a day. On the 10th day remove from frig and rinse the meat off, then place in a container of cold water(I use a 5 gallon bucket). Let soak for 4 hours. Put back in the frig for 24 hours to form a skin on the meat so that the smoke will adhere to it. Smoke at 180 degrees until the meat reaches a temperature of 140 degrees internally. This is the best recipe that I have found for ham and bacon. Use however much brown sugar and pepper you want, but use the recommended amount of salt. |
| Back to top |
Posted: Tue Dec 25, 2012 12:21 pm Post subject: Re: Pink salt curing |
Thank you for the info! |
| Back to top |
Greg1959 Long Time User
Posted: Tue Dec 25, 2012 12:47 pm Post subject: Re: Pink salt curing |
Chill ham to 40 degrees Fahrenheit immediately upon slaughter. Plan to start curing ham during the cool weather months of December and January, unless mechanical refrigeration is available. Ham requires four to six weeks of nighttime temperatures at less than 40 degrees Fahrenheit. Curing ham at higher temperatures will induce spoilage.
2
Prepare ham for curing by trimming excess fat. Leave at least 1/4 inch of fat covering the meat.
3
Apply cure 24 to 48 hours after ham has chilled. There are many recipes for curing mixes and it just depends on ones preference as to which one to use. A basic mix consists of 2 lbs. non-iodized (canning) salt to 1 lb. sugar. Add cayenne pepper, red pepper flakes or black pepper for a spicier flavor. Approximately 1 1/3 ozs. of cure is needed for each pound of ham.
4
Cover the working area with newspaper and lay a large sheet of freezer wrap, or other meat packaging paper, on top of the newspaper. Place the ham on the freezer wrap.
5
Pull the meat from nearest the bone on the hock end of the ham and pour ¼ cup of cure seasoning inside. The hock end is the meatier end of the ham. This is essential for curing the central part of the ham and reducing the chance of spoilage.
6
Rub cure seasoning all over the ham with your hands, paying careful attention to any crevices. More cure seasoning is typically better than less.
7
Position the ham in the center of the freezer paper and wrap the ham tightly with the freezer wrap. Don't roll the ham to wrap, pull the paper up around the ham. You want to keep the cure seasoning intact as much as possible.
8
Twist each end and ease the wrapped ham into a clean panty hose stocking. Work it all the way to the bottom of the stocking. Do not use tape or seal the ends. The ham must be able to release juices in order to cure properly.
9
Hang in a cool, dry place. Curing typically requires hams to hang three days for each pound of meat.
10
Remove ham after curing period. Unwrap the ham, remove cure along with any mold that has developed. A cloth saturated with apple cider vinegar can be used to wipe moldy areas from the ham. Allow to dry for about 30 minutes and rub the ham down with vegetable oil.
11
Rewrap the ham and return it to the panty hose stocking. Place in a well-ventilated area to age. Hams can be hung and allowed to age for a minimum of three months and for as long as six months. |
| Back to top |
Rob03 New User
Posted: Tue Dec 25, 2012 1:01 pm Post subject: Re: Pink salt curing |
Greg 1959
We used to do our hams like that when I was growing up and we butchered hogs in the fall. A good country ham is hard to resist if done properly. Dad would use what was called river salt along with brown sugar and different peppers. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
