Early timing gears and late timing gears
buickanddeere
PostPosted: Tue Dec 25, 2012 1:48 pm    Post subject: Early timing gears and late timing gears Reply to specific post Reply with quote
This message is a reply to an archived post by Mikes806H on December 14, 2011 at 12:32:07.
The original subject was "Detroit diesel 453N timing gears".
There are early "soft" timing gears and late "hardened" timing gears. Don"t mix them or the hard gears will mill the soft gears.
I have most of an aluminum block 3-53 in the shed. Thought it would make a great stealth engine upgrade in a 435 puller if the hood was stretched.
Engine has stripped timing gears. Never got around to opening it up to find why.
When building the engine use N sleeves and pistons. And C50 injectors. Upgrade the blower seal after using the cutting tool.
